Old 11-01-2009, 09:46 AM
p27182's Avatar
p27182 is on a distinguished road
Need Servo Driver ID'd!!! (pics inside)
They are out of my Anilam/Lagun 2cnc mill.
if anyone has specific info on these that'd be great!
I have some documents I got from jerry but there is one wire that is a mystery to me...
thanks for any info or help!
-pat
Name:	servoCards 008s.jpg‎
ID:	92484   Click image for larger version
Name:	servoCards 007s.jpg‎
Old 11-01-2009, 09:57 AM
Al_The_Man's Avatar
It looks suspiciously like a Westamp, I have the manual on the A651 and the layout and pin connectors look very close.
EG&G were noted for their relabelling.
What connector pin does the wire correspond to?
Old 11-01-2009, 10:04 AM
p27182's Avatar
thanks Al!
any chance I could get a hold of that manual? (assuming its in pdf form).
the "mystery wire" on the Z and Y cards is one wire going to the 8th pin on the header that receives the analog signal (10th pin if you coulnt the pins that are cut off).
Thanks!
-Pat
edit:
is this in ref to the same manual?
http://www.cnczone.com/forums/showthread.php?t=17510
thanks again!
Old 11-01-2009, 10:32 AM
Al_The_Man's Avatar
It looks like you have a few more pins on that model, What are you trying to do actually?
Is this for trouble shooting or re-using them?
Is there a possibility of tracing the mystery wire back?
Apart from the analogue signals and some aux power outputs, and of course the commons, the other inputs are usually +- limits, tach and drive-enable.
The previous post is the one I referred to.
I have manuals on two different models and in both cases the pin 8 is enable.
Old 11-17-2009, 12:16 PM
p27182's Avatar
Al, I wanted to ask you what you would do in the following situation:
The drives seem to drift, meaning that when I ground out the analog control signal input, they still move- Adjusting the balance pot has no effect but as a single component seems to function. (I tried adjusting the pot while the input was grounded out with no change in motor behavior. The motor still creeps in one direction at a consistent velocity.)
I DMM'd the pot while still in the circuit and do see a changing resistance value (without power applied).
any suggestions or ideas?
Thanks!
-pat
Old 11-17-2009, 12:30 PM
Al_The_Man's Avatar
I know the pots were a notorious source of problem with these amps.
Rather than spend alot of time on them, I usually ended up changing them for A-M-C or Copley Control drives.
Old 11-17-2009, 01:03 PM
p27182's Avatar
sounds expensive.
would you mind linking me to a source?
Thanks again.
-pat
Old 11-17-2009, 01:32 PM
Al_The_Man's Avatar
This is link to A-M-C, I often look for them on ebay.
http://www.a-m-c.com/
You can also use their BLDC drives as they are designed to run DC brushed also.
This has the advantage that if you lose a motor at a later date, you can upgrade to a BLDC at not extra cost for the drive.
[IMG] code is Off
Need Help!- Trying to Identify Servo Drive? see pics gurvy Servo Motors and Drives 2 11-22-2008 04:28 PM
Servo driver karl1 General Electronics Discussion 21 03-21-2007 08:51 AM
M.E. Project (pics, lots of pics) skmetal7 CNCzone Club House 2 01-08-2007 03:30 AM
Setting up my steppers, pics inside. Darc Mach Software (ArtSoft software) 5 10-15-2005 12:33 AM
Have almost all my parts (pics), need servo advice Darren_T DIY-CNC Router Table Machines 27 01-06-2004 08:20 AM
