Old 03-14-2005, 11:38 PM
murphy625 is on a distinguished road
What servo drives use resolver inputs?
I am using a Digitax drive (Control Techniques) and it accepts only the resolver type signals.
I have 2 motors that I want to use that both have resolvers.. These 1.3KW motors came with the drives.
I want to look for replacement drives for these motors but not sure what manufacturers use the resolvers like Control Tech. does.
Any suggestions?
Thanks.
Old 03-15-2005, 01:58 AM
jevs is on a distinguished road
If you want new drives I am betting everyone is going to suggest you remove the resolvers and get encoders from US digital or somewhere. I don't think any of the new drives are really made for resolvers anymore. I am still a newbie and stuck with my own problems at the moment so I could always be wrong though I just know some people thought my motors had resolvers and that is what they suggested to me. I was lucky though and ended up having encoders.
Old 03-15-2005, 11:51 AM
I am thinking your right... I wish I had known this before I purchased these drives and motors.. (but I got them cheap so oh well).
What drive and servo manufacturer do you recommend? Al the Man tells me he likes the Mitsubishi (sp?) drives but I dont see any used ones around.
This is no toy servo that I need... I require 1.3 - 1.5 KW of power @ 480volts.. (I dont like the 220v systems because the wires get to big)
Thanks,
Murphy
Old 03-15-2005, 12:28 PM
Al_The_Man's Avatar
I believe Baldor makes a drive rated at up to 27amps that takes +-analog or step & dir. has encoder, resolver or hall feedback They are the FlexiDriveII version.
If you have resolvers for commutation (AC motor) then you generally cannot remove them and fit encoders, you would have to add the encoder to the shaft.
The motion cards like Galil etc, will output 2 sinusoidal signals to a more economical drive as made by A-M-C and Copley etc, but this requires 2 axis channels per phyisical axis. so for 2 axis you would need a 4 axis card.
Resolvers were fitted to early DC motors like Fanuc etc because they are noise prone free, but usually are geared up to increase the otherwise low resolution.
Al
[IMG] code is Off
Can Gecko's servo drives be used with steppers? bgriggs Gecko Drives 1 05-26-2005 12:39 PM
Servo drives quickerz Servo Motors and Drives 1 01-21-2005 10:24 AM
Control Technology Corp. Servo drives tpworks General Electronics Discussion 1 04-17-2004 08:59 PM
steppers or servo drives mmjpotter Gecko Drives 14 03-30-2004 02:56 PM
Servo motors, Drives Wolfe General Electronics Discussion 1 11-16-2003 01:47 PM
