Old 03-14-2005, 06:15 PM
jevs is on a distinguished road
Fanuc motor ???
Well I have been stuck on this project for about a month now. No one in the world seems to know the specs on the motors my machine has. I don't know why, because I can find them listed all over the net for sale or to repair them. The main problem is that there is no part number on them that starts with an A0. Here is all the information off the motor plates. If anyone knows voltage and current specs let me know. I have everything except power supply and drivers for the retrofit. I can't do anything more till I figure out some specs on these motors. I tried powering it up with a home made 3 phase converter today, but I can't get the control to do anything. It is like it is stuck in an E-stop condition. The controller lost all its parameters due to a dead memory battery as well. I can't get it it to accept them though because the ready light will not come on.
Z axis:
Fujitsu Fanuc LTD
Fanuc DC Motor 0
Type: 0-2000M
NO: D-771719
Date: 77 10
Permanent Magnet DC Servo Motor
X,Y Axis
Fujitsu Fanuc LTD
Fanuc DC Motor 5
Type: 0-2000M
Date: 77 10
Old 03-16-2005, 01:23 PM
Al_The_Man's Avatar
Here is a Fanuc 5M on ebay http://cgi.ebay.com/ws/eBayISAPI.dll...500128195&rd=1
It shows 151vdc at 9 amps also shows the torque.
Al
Old 03-16-2005, 01:36 PM
Mine looks a little different than that. It doesn't have a yellow cap and the motor plate looks differnt. Mine just have a 5 or a O and no M. Where that one says 2000H mine says 2000M. I did find the part numbers finally even though they aren't on the motors.
A06B-0614-B031 for the x and y motors (have 5 on them)
A06B-0613-B031 for the Z axis (has 0 on it)
Maybe I can get some specs now that I have a part number. That 5M does look about the same size and maybe these are very similiar to that one, but I goot know without a doubt before I spend money on drivers.
Old 03-16-2005, 04:47 PM
I got a bunch of new information on these motors. Here it is:
Servo Motors
Fujitsu Fanuc LTD
Fanuc DC Motor 0 (z axis)
Type: 0-2000M
NO: D-771719
Date: 77 10
Part Number A06B-0613-B031
Output Power: 0.4 KW (0.5 HP)
Rated Torque: 28 Kg-Cm
Max. Torque: 240 Kg-Cm
Max. Speed: 2000 Rpm
Rotor Inertia: 0.029 Kg-Cm-S 3
Back EMF Constant: 25 V/K RPM
Torque Constant: 2.44 Kg-Cm/Amp
Mechanical Time Constant: 25 mSec
Thermal Time Constant: 50 Min
Weight: 12 Kg
Fujitsu Fanuc LTD
Fanuc DC Motor 5 (x,y axis)
Type: 0-2000M
NO: D-771719
Date: 77 10
Part Number A06B-0614-B031
Output Power: 0.8 KW (1 HP)
Rated Torque: 55 Kg-Cm
Max. Torque: 480 Kg-Cm
Rotor Inertia: 0.05 Kg-Cm-S 3
Back EMF Constant: 50 V/K RPM
Torque Constant: 4.87 Kg-Cm/Amp
Mechanical Time Constant: 15 mSec
Thermal Time Constant: 55 Min
Weight: 16 Kg
Now, how do I caclulate what Voltage I should run to the drives for these and how would I calculate the max current rating needed??
[IMG] code is Off
Fanuc 0-2000M DC servo motor ?? jevs General Metal Working Machines 2 02-14-2008 01:27 PM
Fanuc 0-2000M motor ?? jevs Servo Motors and Drives 6 02-18-2005 01:46 PM
Xylotex/TurboCNC/stepper motor set up problem buscht Xylotex 5 08-31-2004 08:16 AM
Servo's - oversupplying voltage for speed AJ_Mac2001 General Electronics Discussion 15 01-17-2004 10:32 PM
fanuc servo motor moving without command mtech General Metal Working Machines 5 06-16-2003 08:39 PM
