Old 09-11-2009, 03:41 PM
Thomasdj is on a distinguished road
Question aboout motor/drive match
I want to run my spindle with a servo motor and yesterday I picked up a BNIB mitsubishi 750watt servo drive from ebay..
Can I use a 400watt servo motor if I adjust the "high torgue limit" Pot/resistor to a fixed resistor with correct value?
It's not because I don't like the 750watt ..but the falnge size is to large
Best regards
Thomas
btw..Can I use other brands or do the motor have to match the driver exactly?
Old 10-05-2009, 04:46 AM
battwell is on a distinguished road
the mitsubishi servo motors and drives are matched pairs. the 750 drive will only run 750 motors etc. they show a fault code if connected to wrong motor. the drive queries the encoder which tells it what motor size it is. they are serial encoders so no fooling them!
so much to learn, so much to pass on.
[IMG] code is Off
Question ? - What hobby CNC servo driver will drive a 12Volt DC motor FPV_GTp Servo Motors and Drives 25 10-27-2010 01:37 AM
Question - X2 motor isolation for belt drive george4657 Benchtop Machines 4 08-21-2009 08:00 AM
Simple, 3 Axes with Dual Drive/Motor (per axis), hardware splitter drive Interface. kreutz Stepper Motors and Drives 3 07-03-2008 06:57 PM
Stepper Motor Belt Drive Side Load Question harryn Stepper Motors and Drives 3 08-07-2007 05:23 PM
X1 and X2 mix and match acondit Benchtop Machines 14 12-05-2005 03:11 AM
