Old 07-26-2009, 01:41 PM
MWJ2009 is on a distinguished road
Info on Panasonic Servo Motor
I have a linear drive unit designed by Hirata Robotics.
It uses a Panasonic Servo Motor with the following label:
Model: MSMO42F2G
Serial: 97100086
I have been unable to locate any specs, wiring diagrams, etc. From the manufacturer. See attached.
Can anyone help? Thanks!
Name:	pic 007a.jpg‎
ID:	85045   Click image for larger version
Name:	pic 021a.jpg‎
ID:	85046   Click image for larger version
Old 08-06-2009, 04:10 AM
Old Poni is on a distinguished road
Smile
Model: MSMO42F2G
Serial: 97100086
Hi
Try this link. I hope it could help you http://industrial.panasonic.com/ww/i..._acs_e/a4.html
Old 08-06-2009, 11:56 AM
CNCMAN172 is on a distinguished road
Smile Old Poni
Hey Old Poni,
I use Panasonic servo motors and drives all the time, so let me give you a few pointers. Like the previous user shared many documents are available on the web, however you will never find some of the ones you will want.
MSMO42F2G
There are some similarities and some differences as you play with various Panasonic Minas servos and drives.
MSM is often also referred to as MSMA
04 = 400 watt motor
2 = 200VAC driver required to drive this servo, if this number was 1 it would have been 100V or 120VAC
The cryptic part of the part numbers are the F2G
The F is normally the encoder style and the 2G are typically the type of seals, shaft style, keys, etc.
Panasonic has different kinds of encoders. Incremental and Absolute to start with and sometimes it is difficult to identify them. The first thing to do is count the number of wires coming out of the encoder and determine their colors. 11-wires which might be the one you have is an indication of an incremental encoder with 2500ppr quadrature encoder. If you check some of the manuals for say the Minas MSD drivers you will find a pin out for these with wire colors. Check and see if you wire colors match, if you you are almost ready for prime time. The power side of things is pretty straight forward three phase power and ground. The drivers typically need to be programmed to match the type of input you plan to drive the system with so that will be the next stage. If you need more let help let me know and I will try and provide you some pointers.
CNCMAN172
Old 09-30-2009, 02:37 PM
damiens is on a distinguished road
Panasonic has discontinued lots of different servo series they offered before. As far as I know their minas A & E series servos are the only ones supported now. You can take a look at the following page, it has 4 different series datasheets/manuals.
http://www.clrwtr.com/Panasonic-Servos-Motors.htm
Tags
hirata, panasonic, servo
[IMG] code is Off
Help Need Info On Vexta Servo Motor m.southern Servo Motors and Drives 9 10-13-2011 10:58 AM
Need Help!- Can't find information on Panasonic servo motor vova Servo Motors and Drives 0 12-22-2008 05:26 AM
Panasonic AC Servo Motor....I think???? hansenmick Servo Motors and Drives 2 03-27-2007 12:10 AM
Info Needed Omron 500 W Ac Servo Motor robo_plasma Servo Motors and Drives 0 01-06-2007 06:30 PM
Servo motor info please! mmmjboner Servo Motors and Drives 1 12-14-2006 09:52 AM
