Old 07-02-2009, 09:52 AM
Methias is on a distinguished road
Servo Motors - Silly Question
Would there be any reason not to use a servo from an RC plane (the more powerful ones) to drive a small CNC machine? Obviously remove the stops to allow it to continuously rotate.
Maybe something like this (Although its not THAT strong, if the CNC machine was light enough, or would gearing help?)
* Dimension : 40mm x 19mm x 43mm
* Weight : 52g
* Operating Speed :
o 0.17sec / 60 degrees (4.8V no load)
o 0.13sec / 60 degrees (6.0V no load)
* Stall Torque :
o 13kg/cm at 4.8V
o 15kg/cm at 6V
* Temperature Range : -30 to 60 Degree C
* Dead Band Width : 4 usec
* Operation Voltage : 4.8 - 7.2Volts
* Motor Type: 3 Pole Ferrite
* Potentiometer Drive: Indirect Drive
* Bearing Type: Dual Ball Bearing
* Gear Type: All Metal Gears
* Connector Wire Length: 11.81 inch (300mm)
Old 07-02-2009, 12:36 PM
ger21's Avatar
Way too slow?
Old 07-03-2009, 01:19 AM
Okay so the rough RPM of the motor is 77RPM. Is the normal range in the thousands?
Old 07-03-2009, 01:25 AM
ger21's Avatar
It can vary greatly, but usually 2000-6000rpm.
Old 07-14-2009, 06:26 AM
dmmcnc is on a distinguished road
RC motor?
Basically there should be a high resolution/accuracy encoder to feedback
position information, otherwise how to know where the motor angle is?
regards
HL
www.dmm-tech.com
[IMG] code is Off
no doubt a silly question but... rich_cree Gecko Drives 17 01-17-2009 04:10 PM
Newbie- Probably a silly question... cNcCharlie WoodWorking 6 07-01-2008 03:19 PM
Newbie- Silly Question Smitty911 CamBam 5 02-11-2008 03:30 AM
Silly question but need to know Scalesoar WoodWorking 7 01-19-2007 11:31 PM
Few question about servo motors ... efrem Servo Motors and Drives 1 07-05-2006 09:42 PM
