Old 06-28-2009, 05:38 PM
veteq is on a distinguished road
ac vs dc brushless
Hello guys,
can a ac bruchless servo motor be driven by a dc servodrive?
what are differences?
I would like to buy these motors
http://www.apicontrols.com/newapi/pr...urbo_over.html
these are ac right?????
is i would use the granite devices, are they different wired then dc
or do i need to configure the drives different?
regards,
roy
Old 06-28-2009, 06:10 PM
Al_The_Man's Avatar
A DCBL with hall effect commutation requires a DCBL drive, the AC Sinusoidal is constructed virtually identical to a BLDC, but if fitted with resolver feedback requires a Sinusoidal drive.
A DC brushed can be driven with a DCBL drive set to 60deg commutation.
I believe Granite drives will accept encoder feedback for commutation, but you would have to confirm this.
It appears the motors in the link are dual purpose, depending on the feedback option fitted.
Old 07-14-2009, 06:19 AM
dmmcnc is on a distinguished road
DC or AC brushless motor
Hello;
The DC servo drive can not drive AC brushless motor.
But GD's drive have both functions to drive either DC or AC brushless motor,
you need to set the drive configuration, also make sure the AC brushless motor you want to buy has the 3 phase hall sensor signal U,V,W, and the
enocder signal available for position servo control.
regards
HL
www.dmm-tech.com
[IMG] code is Off
Need Help!- AC brushless Olsson Servo Motors and Drives 0 04-16-2008 12:20 PM
Can I use these brushless motors? runinbymdnt DIY-CNC Router Table Machines 1 10-03-2006 04:08 PM
Brushless DC servos VS. Brushless R/C motors sp1nm0nkey Servo Motors and Drives 1 03-07-2006 09:37 AM
AC Brushless vs DC Brushless h3ndrix General Electronics Discussion 5 03-25-2004 09:29 AM
