| Servo Motors and Drives Discuss servo motors, drivers and other related topics here. |
After removing the plastic pulley, I found that the motor shaft diameter is .234 inches. The new pulleys that I have, have an inside diameter of .250" This causes a slight wobble. What would be the best way to correct this situation ? Should I try to lathe out a small sleeve, .016 aluminum foil etc. I have also completed the prototype reducer assembly, here are some pictures. Thanks Last edited by Iron-Man; 06-15-2009 at 06:45 PM. Reason: .250" not .025" |
I always buy my timing pulleys with the smallest hole they come in, and turn the ID to the desired size. This also allows me to assure the hole is concentric - I have had some that were outrageously off-center. Jon |
I have a kit of brass shim stock in over a dozen sizes. I think brass would work fine. If you have steel, that will work just fine, too. I have not seen aluminum shims in the thinner gauges, and would worry about the aluminum cold-working (squeezing) out of the space between pulley and shaft as the pulley rotates and works against the shaft. Brass has worked for me in a few places under these circumstances for years. Jon |
| Newbie- Universal Magnetics Servo Motors | Iron-Man | Servo Motors and Drives | 3 | 01-25-2009 02:46 PM |
| New Machine Build- Looking for AC universal motor driver circuit scheme | bedo | DIY-CNC Router Table Machines | 2 | 08-17-2008 03:33 PM |
| Sell Servo Motor, Servo Drive by GSKcnc.com from China | salecnc@hotmail | Product Announcements & Manufacturer News | 0 | 06-03-2008 02:55 PM |
| dc series universal motor | jed102 | Servo Motors and Drives | 6 | 05-02-2007 09:09 PM |
| "Universal" AC/DC motor | Swede | General Electronics Discussion | 1 | 02-17-2004 02:16 PM |
