Old 06-01-2009, 04:13 PM
RP Designs is on a distinguished road
Which drives?
Ok, so with AjaxCNC not really earning any sort of trust, I am now in the position of building my own control. I would like to upgrade the circa 1986 drives in my dead Fanuc 10MA control while retaining the servos and encoders. I have looked into the Gecko's, Rutex, and Granite drives and haven't really decided which is going to be the best route.
For my X and Y axis, I have Fanuc 5m servos with 2000 PPR encoders. These motors are rated at 151 volts, 9 amps and 2000RPM (continuous at stall). The Z axis has a Fanuc 0M motor rated at 96 volts, 7.2 amps and 2000 rpm (also continuous at stall). What drives would be suitable for these motors? I am not sure I can wait the 2-3 months for the new 160V granite drives.
Old 06-01-2009, 04:22 PM
samco is on a distinguished road
I think you options are few if you want step/dir. What are you wanting to use for control software? (mach, emc2...?)
sam
Old 06-01-2009, 04:26 PM
I am not sure which one I want to go with yet. I am leaning towards emc, but may go down the mach path.
Old 06-01-2009, 04:36 PM
If you are using emc2 - you could use industry standard drives that take pwm/dir, +/-10v... Like AMC or such. You would need i/o boards that would output that. They start at about $90 for the mesa 48 i/o board.
Look here http://wiki.linuxcnc.org/cgi-bin/emc...orted_Hardware
Pico systems sells amps also that are rated to 150v 20a.
http://jelinux.pico-systems.com/pwmservo.html
take a look at mesa also.
http://mesanet.com/
All of these setups allow closed loop back to emc2.
Research research research
sam
Old 06-05-2009, 01:58 PM
osdhillon is on a distinguished road
Post centroid servo controller
Hi guys,
I have centroid 2KW and 3KW AC servo motors. Which Servo drive can I use to run it? Can any body help.
Old 06-05-2009, 02:14 PM
MattTheNoob is on a distinguished road
I'm in the middle of a '80's retrofit myself, with similar sized axis motors, and my initial tests with gecko 320's was very positive. Ok, you will limit your top speed with the 80v maximum, but it'll probably still be faster than the original machine. My bosto was originally 100imp max, presumably because of the processing speed of the '80's controls, but the gecko 320's at 72v + mach 3 easily exceeds that. I don't recall the exact speed I got during the test, but you can calc it with your motor rpm/v, and ball screw pitch.
Old 06-15-2009, 03:28 PM
Matt Adams is on a distinguished road
Originally Posted by osdhillon View Post
Hi guys,
I've visited the folks up at Centroid. I believe that they use brushless AC motors with incremental quadrature feedback. I know that most of their drives operated best with 240 VAC.
Kollmorgen drives can operate those motors (which i believe are actually manufactured in England)
Let me know if you want more information.
Matt
Matt Adams - Motion Control Application Engineer
IMAC Motion Control - Elgin, IL
Old 06-15-2009, 03:32 PM
matt
thanks for the info. Where can I get more info regarding these drives. What kind of signal does these drives accept.
Old 06-15-2009, 03:40 PM
Post
Kollmorgen S300 drives.
They accept quadrature input, analog +/- 10 VDC, step and direction. Also can operate over SERCOS, Profibus, CANOpen, Ethercat field bus protocols.
3,6, 10 Amps continuous @ 240 VAC 3 Phase.
http://www.danahermotion.com/website...00_Catalog.pdf
If you're interested, I can provide you pricing and help you set them up.
Matt
Old 06-15-2009, 03:53 PM
I am very interested. Can you please send me e-mail @ osdhillon@gmail.com with pricing and a number I can reach you.
Onkar
  #11   Ban this user!
Old 06-21-2009, 07:44 PM
Larken is on a distinguished road
Check out the mill retrofits that use Viper 200 drives. They match your Fanuc motors well.
http://www.viperservo.com/V200.htm
http://www.viperservo.com/V200apps/V200_apps.htm
Manufacturer of CNC routers and Viper Servo Drives
www.LarkenCNC.com and www.Viperservo.com
[IMG] code is Off
New Drives Mariss Freimanis Gecko Drives 25 09-04-2009 05:35 PM
RTA Drives mkc2 Stepper Motors and Drives 0 06-10-2008 09:36 AM
12v drives chester1957 General Electronics Discussion 10 01-03-2008 06:53 AM
Can someone help me with these motor/drives, I think the drives are dodgy? Darc Stepper Motors and Drives 1 07-23-2005 06:31 PM
can you ID these drives SJ781 General Electronics Discussion 0 04-27-2004 09:16 PM
