Old 02-03-2005, 05:57 PM
Bird_E is on a distinguished road
Any one using the Cliffton Servo's?
Just curious if anyone is currently using the cheap cliffton servos on a CNC project. How are they working for you? What power supply/encoders and servo drives are you using with them?
THanks!
BOb
Old 02-03-2005, 06:08 PM
trubleshtr is on a distinguished road
I'm sitting on a set of them, and will be using them with rutes drives. I have crappy renco encoders that are not differential, and had to also buy a board to make the encoders usefull over long wire spans, that also was purchased from rutex. I would recommend using a diff. encoder from usdigital, if you don't yet have encoders.
I also have in the works a home made power supply to drive the servos as they require about 40~50vdc.
I am currently waiting on rutex for a few things, once I get them I will be able to bench test my set-up. Although I have learned alot along the way, I think next time I would buy a complete (powersupply to servos) off the shelf system to save on build time.
menomana
Old 02-03-2005, 09:28 PM
Al_The_Man's Avatar
Renco make all kinds of configurations, including differential, I have had no problem with them so far.
Al
Old 02-03-2005, 09:53 PM
kenlambert's Avatar
kenlambert is on a distinguished road
mine are working just fine I use the machine every day ,I havent had any runs over 2 hours but so far no problems . Useing gecko 321 , mach 2 and a home made power supply , US digital encoders .
thanks Kenneth
web-www.lambertsrc.com
Learning CNC
Old 02-03-2005, 11:41 PM
cnc2k is on a distinguished road
Is this the same motor as the one Jeff's selling?
Old 02-03-2005, 11:52 PM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
Yes it is.
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 02-04-2005, 07:55 AM
tjstraz's Avatar
tjstraz is on a distinguished road
I have three of these on my 48"x30"x8" Router that I built. I have them powered with a 36V Power supply and Gecko 320s. I'm using U.S. Digital encoders. I have had my machine running for 16 hours at a time. Very pleased with them.
Tim
Old 07-03-2005, 12:45 PM
Adler is on a distinguished road
Anyplace you know of that sells them ?
Old 07-03-2005, 05:14 PM
alnicov is on a distinguished road
http://www.automec-direct.netfirms.c..._dc_motor.html
Old 07-03-2005, 07:15 PM
Thank you.. price certainly is right. Did you mount the US Digital encoders directly to the servo motor ? Regarding the resister and capacitor mentioned on the Cliffton site...using them?
trubleshtr any reccomendations for an off the shelf system. I'm building a 48" X 60" Co2 Laser cutter for light duty.
Thanks, Craig.
Old 07-03-2005, 09:54 PM
ger21's Avatar
Those motors are sold out.
[IMG] code is Off
What all parts to convert cnc jr to servos? blazer928 Servo Motors and Drives 3 11-15-2006 02:01 PM
Servos pausing and starting InsaneEPP Servo Drives 9 03-15-2005 09:45 PM
Brushles DC Servos works in CNC? Yepez Servo Motors and Drives 4 12-05-2004 01:02 AM
Two servos - one driver WoodSnarfer DIY-CNC Router Table Machines 8 11-13-2004 05:46 AM
Servo's - oversupplying voltage for speed AJ_Mac2001 General Electronics Discussion 15 01-17-2004 11:32 PM
