Old 05-30-2009, 03:50 AM
traxxtito is on a distinguished road
yaskawa servo drive
hi all
i need your help for my yaskawa servo driver problems .
frist of the problem when the boy made wrong wire connection , he gives one one of the sensors on the machine 3 phases (380V) and powering on machine ... it had to boom and the main power shut down .
we found many corrupted resistors and relays in the operator board and main control board ... we change it .
some changing happened in solve problem direction .
but now i have no move for all axis and if i try it i get alarm ( over servo lag )
and i have signal in all servo drivers screen ... it means ( difference between the motor speed and reference speed is below preset value )
pls. can you tell me what's possible was happend when the sensor was take 380v
and now what i can solve it .
its urgent pls.
Old 05-30-2009, 09:29 AM
Al_The_Man's Avatar
There is obviously something still blown on the board the sensor was connected to, could be a power supply or burnt traces, almost immposible to diagnose this kind of problem from a distance.
Old 05-30-2009, 06:10 PM
hi al.
thanks for your reply .
so , you mean we must check the all board in machine or servo driver board ?
and if you know any thing about this problem and it solve pls. tell me how i can ?
and if i can get technical support from yaskawa in egypt ... r u know it ?
pls. following with me
[IMG] code is Off
Trouble with Yaskawa Drive & Servo curtisturner Servo Motors and Drives 4 04-28-2011 12:57 AM
Yaskawa SGDH and SGDA servo motor/drive wiring questions rpseguin Servo Motors and Drives 62 12-02-2009 06:43 AM
Running Yaskawa drive with RPC ticica Phase Converters and VFD 3 04-25-2009 07:59 PM
Yaskawa Drive + Pixie 100 curtisturner Servo Motors and Drives 2 08-07-2007 11:06 PM
problem with Yaskawa V7 drive rebrumm Phase Converters and VFD 4 05-22-2006 04:40 PM
