Old 01-29-2005, 11:56 AM
Bryscnc is on a distinguished road
Exclamation German DC servo motor, will these work
This is my first post, although I been reading posts for a long time.
I come across some German servo motors and I need help on whether they will work. I know they came off a conveyor system. The ID tag reads: PM MOT, TYPE 13 121 65 5 2 6, Nr. 1/9906/2547, 370 W, 3000 1/min, Errg. PM V, I max. 11.2 A, Anker 180 V, 2.5 A, Ff 10, IP 44 . They have encoders or tachometers on the backside and are connected to a reduction gearbox. I have a southbend mill 9x49 that I want to convert to cnc. I would like to know what kind of torque or power they have, then if they will work, is there an inexpensive drive that will handle the 180 volts required.
Old 01-29-2005, 12:26 PM
Al_The_Man's Avatar
Are they AC or DC brush servo's? Although at 3000rpm probabally DC, If the units on the back have only two wires they have tach's.
370w works out to around .5hp at 3000 rpm, so they would be a bit light for your application, but it depends on wether you can use the gearboxes, ratio etc and wether they are precision, low back-lash type.
There are quite a few drives always coming up on ebay such as A-M-C and Copley Controls for two. If the motors are fitted with tach's you could replace them with encoders and pick amplifiers that can be configured for Torque mode of operation where the tach's would be redundant.
Al
Old 01-29-2005, 12:40 PM
Thanks for the info. What size would be sufficient and could you give me and ballpark cost. I'm still thinking about maybe using stepper motors, but the cost will be the determining factor.
Old 01-29-2005, 01:03 PM
Old 01-29-2005, 01:11 PM
Al_The_Man's Avatar
Something like this would probabally do the trick, http://cgi.ebay.com/ws/eBayISAPI.dll...868610838&rd=1 the servo's I have on the Excello mills I have (8x36) are 26"lbs DC motors reduced by about 2 to 1, but that would be the largest you should require. It depends on the demands you place on the mill, servo's are the way to go, but obviously stepper are more cost effective.
But if you go the ebay route, you can level the cost difference out somewhat.
Al
Old 01-29-2005, 01:44 PM
Gold Member
lerman is on a distinguished road
On the subject of Servos, what am I missing about these?
http://www.servosystems.com/servo_motors_surplus.htm
Stock No. DM-599
Micro Electric Brushless Motor SE1008
P/N 409905---/00
(055) With brake and encoder mount
(053) No brake with encoder mount
(147) No brake, no encoder mount
3.1 KW, 220 VDC, 14.9 A, 200 Hz, 3000 RPM
Bargain Price . . . . . . . . . $162.50 ea.
Micro Electric SE1008 Servo Motor with Encoder
Stock No. DM-600
Micro Electric Brushless Motor SE1128
P/N 409905---/00
(059) With brake and encoder mount
(057) No brake with encoder mount
(163) No brake, no encoder mount
4.4 KW, 220 VDC, 20.9, 200 HZ, 3000 RPM
Bargain Price . . . . . . . . . $200.00 ea.
These are big honking motors for not much money. What does the 200 HZ mean? If I built a variable frequency drive for it, could I use it as the spindle motor on my Bridgeport?
Ken
Kenneth Lerman
55 Main Street
Newtown, CT 06470
Old 01-29-2005, 02:23 PM
HuFlungDung's Avatar
Moderator
Do "German servo motors" respond to a "Stop" command or does a "HALT" command have to be used?
Old 01-29-2005, 03:18 PM
arvidb is on a distinguished road
The 200 Hz means you have to run them at 200 Hz to get 3000 RPM. 3000 RPM = 50 revs/s so I guess that means they are four pole motors?
Also since they've got encoder mounts I guess they don't come with encoders. And they look very wide, perhaps this is some kind of high inertia motor that is not as good as normal servo motors in terms of acceleration? Just guessing...
Arvid
[IMG] code is Off
How do Servo Motors Work? Sanghera General Electronics Discussion 37 06-06-2009 01:00 PM
Small servo systems and power supply imserv Product Announcements & Manufacturer News 4 04-03-2008 12:11 PM
Servo Motor Running away. murphy625 CamSoft Products 38 02-27-2005 02:08 PM
Work Holding Methods InventIt DIY-CNC Router Table Machines 13 09-14-2004 04:13 AM
steppers or servo drives mmjpotter Gecko Drives 14 03-30-2004 03:56 PM
