| Servo Motors and Drives Discuss servo motors, drivers and other related topics here. |
http://i59.photobucket.com/albums/g2...uch/wiring.jpg Hi I bought a couple of these S series Minas drives off ebay. Im about to power them on for a test, there is an inline AC filter and a 3 amp fuse in the plug, should this be sufficent to test the drive without any load? Should I be using the green ground termianls on the drive, you can see them in the picture above. What should I connect them to? Cheers Gav |
| The ground conductor appears to be connected from filter to drive via the 3 conductor cabke? The supply to the filter should include a service ground. Al.
| You should be OK to connect as you suggest, as long as the filter is rated for 240vac. Normally these filters require a ground to function as some of the components are referenced to ground. Although it would not stop power up. There is also the safety aspect anyway. Al.
| Well I flipped the switch... and everything seems ok. Green lights and no funny noises or smoke.Now I need to hook up my Step and Direction signal from Mach, I dont have a breakout board yet so I was planning on just using an old printer cable and some terminal blocks to connect the wires and keep them from touching. Is a breakout board really required are there any safety features that will protect my drive from damage? apart from optoisolation which I hear is more for the pc's benifit than the drive. |
| Speed Controller Wiring - check me | TravisR100 | General Electronics Discussion | 4 | 04-06-2009 08:12 PM |
| How to check Laser power supply? | glintid | Laser Engraving & Cutting Machines | 2 | 01-05-2008 06:32 AM |
| Encoder wiring help needed | dfstrasser | General Electronics Discussion | 5 | 03-01-2007 08:00 PM |
| Can someone check my math? DC Power supply. | pfarber | General Electronics Discussion | 2 | 11-30-2006 12:43 PM |
| Power supply wiring help needed | DJ Morrow | General Electronics Discussion | 1 | 10-26-2005 11:05 PM |
