Old 05-11-2009, 09:38 PM
nhatson.elec is on a distinguished road
Omron av servo motor
Any body know , it's motor had how many pole?
thanks you very much
Old 05-30-2009, 03:24 PM
elektriker is on a distinguished road
Hallo nhatson.
a think.. blue and white is phase 1
and green and red is phase 2..
give him 30-35 Volt AC..
his make work..
Encoder pin 25 und 26 has give you 5 Vpp of Oscilaskop..
a think so..
a have make a reparier with tornos maschin baujahr:2007
Gruss Demir.
Old 05-30-2009, 03:29 PM
Al_The_Man's Avatar
I would think it would be more like the three stator connections red,white,blue and green ground, a resistance check would confirms this.
This would apply for DCBL or AC sinusoidal.
Old 05-30-2009, 05:02 PM
I want control it with FOC, for that reason, i need check it had how many pole ?
any body help me
thanks alote
Old 05-30-2009, 07:13 PM
Al_The_Man's Avatar
If the three stator windings checks out as I indicated, wire a 10k resistor to each connection and connect the opposite ends to a star point, this you use as a common for an oscilloscope check between this point and Red, if you rotate the shaft, every positive sine wave output per mechanical revolution x2 will give you the pole count.
Old 05-30-2009, 07:18 PM
Omron..
Hallo nhatson..
you must open the motor and look to.. in motor..
and see this Stator or (Wicklungs-Anordnung)
sorry my english is not so good.
Good Look my Friend..
Gruss Demir.
Old 05-30-2009, 07:37 PM
thanks Al The Man, i'll try
Old 05-30-2009, 07:39 PM
Originally Posted by elektriker View Post
Hallo nhatson..
Gruss Demir.
thanks elektriker
I was open it, but i can't see winding because it cover by epoxy
Old 05-30-2009, 10:06 PM
Thanks Al the man, it have 4pole.
thanks you again
[IMG] code is Off
Sell Servo Motor, Servo Drive by GSKcnc.com from China salecnc@hotmail Product Announcements & Manufacturer News 0 06-03-2008 02:55 PM
Info Needed Omron 500 W Ac Servo Motor robo_plasma Servo Motors and Drives 0 01-06-2007 06:30 PM
Omron 500W AC Servo driver for robot setup robo_plasma Servo Motors and Drives 0 01-06-2007 03:28 PM
omron mmurning General CNC (Mill and Lathe) Control Software (NC) 0 07-26-2005 10:19 AM
New Omron servo; commutation Swede Servo Motors and Drives 9 01-23-2005 12:15 PM
