Old 05-02-2009, 11:50 PM
stevespo is on a distinguished road
Does it exist?
I'm looking for a brush DC servo, NEMA 23, with stats something like:
150 oz/in continuous torque, maybe 450-600 oz/in peak
max 1800 RPM
compatible with Gecko 320/340 drivers (20A 80VDC range)
Do they exist? I'm considering a motor upgrade, but would prefer to direct drive my 5 TPI ballscrews and not mess around with belt reduction. Most small servos have a much higher top speed and require reduction to limit speed and gain torque.
I've done some searching online, but really don't know where to look.
Thanks for any pointers,
Steve
Old 05-05-2009, 07:39 PM
Maybe I'm barking up the wrong tree?
Are these capabilities possible with a small DC servo? I know that I can reduce the RPMs on many common models and get this kind of performance, but are there other options?
Thanks,
Steve
Old 05-05-2009, 08:12 PM
Al_The_Man's Avatar
You most likely will find that DC servo's in NEMA 23 will top out around 100 0z-in continuous.
Old 05-05-2009, 08:36 PM
Al, that's kind of what I have discovered. I did find a brushless servo (Nema 23) capable of 141 oz/in continuous, but that's about it so far.
The most common DC servos seem to be 42-50 oz/in continuous and 350 oz/in peak. I don't have any hard data, but I believe this is a bit marginal for my machine, unless I reduce RPM to gain torque.
My belief (based on my 425 oz/in stepper torque curve) is that 100 oz/in continuous would be adequate for driving my gantry, particularly with a decent peak available when needed.
So, I can reduce a 50 oz/in 2:1 or even 3:1 to gain the torque - or I can try to find a 100 oz/in continuous and direct drive it. In the interest of simplicity (and laziness) I'd like to go the direct drive route. I'm just having no luck finding a suitable motor.
Thanks,
Steve
[IMG] code is Off
Does this lathe turning tool bit exist? cnczoner General Metal Working Machines 7 03-12-2008 08:37 AM
Newbie- Fully Featured Mini Lathe, does one exist? juliancrouch Mini Lathe 10 02-09-2008 10:02 PM
Does this software EXIST ? ZipSnipe General CAM Discussion 16 02-15-2007 07:38 AM
Just curious does this exist ? ? ? scratch_6057 General Electronics Discussion 13 03-18-2006 01:09 PM
Do IMService actually exist? Linus DIY-CNC Router Table Machines 3 09-02-2004 10:02 AM
