Old 04-20-2009, 09:58 PM
wildhorsemfg is on a distinguished road
Help with Bandit cnc /driver servo
I recently got given 4 Bandit cnc systems
One is a trainer that has a plotter (no driver boards)
2 are mostly parts
and the other is a sevo system that
was used on a bridgport very little
and worked a when it was removed about 5 years ago.
I think the logic wors on this machine
but the moters wont lockup turn ect (i alsor tried trimpots)
one motor tunes (By hand) easer one way then the other
The voltage to the boards(driver) is ~75 vdc
One ofthe pars one has bad 5v line (for logic) but the moter hooked to it
has good holding torque.
I think the servo motrs are about 500 in oz.
I also have 3 more 500in oz servos from a parts
machine.
I have thought about going gecko and pc but these motors
have a resolver and that would be more complex
( i would like it to be as cheap a possible of a conversion /fix )
Any help and advice please
cody wildhorsemfg@yahoo.com
www.wildhorsemfg.com machinist / gunsmith
accumax with Fanuc 11M , Harding retrofit (working on)
Old 04-20-2009, 10:02 PM
HuFlungDung's Avatar
Moderator
It is so expensive to revive a Bandit and keep it running, considering the lack of user friendliness of the system even when it runs well. I'd say retro fit it. Take the resolvers off and use encoders instead. Get some modern drives. There is likely nothing wrong with the motors themselves, most Bandits had beefy enough motors for the moderately sized mill.
Old 04-23-2009, 02:11 PM
yes i would like to do a retrofit
but I have 3 or so of every bandit part so I think that it could be fixed with no cost ...i just dont know how to test to find out what is wrong
cody
[IMG] code is Off
Interfacing Mach3 to Bandit Control Stepper Driver Astroboy Mach Software (ArtSoft software) 5 09-01-2008 08:41 AM
Bandit Servo retrofit - drive query nelZ Servo Motors and Drives 1 07-16-2008 05:25 PM
PC to Bandit/Summit driver question bbowers General Electronics Discussion 0 11-27-2007 10:56 PM
Bandit/Summit driver question bbowers Bridgeport and Hardinge Mills 2 11-27-2007 10:24 PM
Bandit - no servo movement Chris64 General Metalwork Discussion 3 09-26-2006 02:23 PM
