Old 04-09-2009, 11:56 PM
Kel05 is on a distinguished road
EMC for sevo
Is EMC software can control mitsubishi, siemens servo driver or amplifier?
If it can , what boards which can control those servos....? Thanks ..
Old 04-14-2009, 07:04 AM
vger's Avatar
vger is on a distinguished road
Are your driver or amplifier PWM input? If so, then you can if you have an interface board like the ones this place sells:
http://jelinux.pico-systems.com/motion.html
This page shows a block diagram of a system:
http://jelinux.pico-systems.com/univpwm.html
Configuration and setup files must also be added to EMC for it to work.
Check the EMC section here on CNCzone also.
Steve
Old 04-14-2009, 07:34 AM
samco is on a distinguished road
Hardware that works with emc
http://wiki.linuxcnc.org/cgi-bin/emc...orted_Hardware
Most common is pwm+dir and +/-10v. Look as pico and masa for good interface hardware. (they include hardware encoder counters also). The masa hardware will do hardware step generation also.
sam
[IMG] code is Off
controller for world sevo products greeny AjaxCNC Control Products 1 04-11-2006 02:49 AM
Litton Sevo Motors and Encoders pjeffers Servo Motors and Drives 0 03-15-2006 09:02 AM
