  #25   Ban this user!
Old 01-15-2005, 12:22 PM
unterhaus is on a distinguished road
Originally Posted by Al_The_Man
You are not refering to an AC servo are you? That sounds like a typical AC induction motor description.
Al
I have heard that some servomotors are induction motors, but I don't know which companies, if any, make them this way
  #26   Ban this user!
Old 01-15-2005, 01:13 PM
Swede's Avatar
Swede is on a distinguished road
For what it's worth, every brushless motor that I have exhibits distinct stiffness when shorted, as Einar suggests. So once again, I am back into the brushless DC camp. The system shipped with 3 brushless motors, unlabeled, which also do this.
My next step is to compare every spec I have on my problematic Parker motors with a motor that I know works fine. There is a slight chance that the one specimen I unwrapped, of the 5 NIB, may be faulted internally, but I think that's a long shot.
I still need to trim the shafts of the brushless MCG's that do run fine so that I can mount them and actually run more comprehensive brushed vs. brushless tests.
This is an informative thread; thanks everybody who contributed.
Old 01-15-2005, 01:40 PM
*Registered*
ESjaavik is on a distinguished road
@Swede: Also check your driver specs. Usually there is a minimum required motor inductance. If your motor have too little inductance for the drive, it may not be able to handle the current rise. I don't know what will happen then, but blowing a fuse does sound like one possible outcome. My drives are directly connected to the line voltage and goes into fault mode in such a case. It took me a while to figure that one out.
  #28   Ban this user!
Old 01-18-2005, 01:29 PM
CNCAddict is on a distinguished road
[QUOTE=Swede]For what it's worth, every brushless motor that I have exhibits distinct stiffness when shorted, as Einar suggests. So once again, I am back into the brushless DC camp.
I'm not sure what you mean by this? Any motor with permanent magnets will resist motion if the leads are shorted. This includes stepper motors and AC servos. Can you elaborate?
David Bloomfield
[IMG] code is Off
brushless motor as spindle? limbo DIY-CNC Router Table Machines 24 03-02-2005 01:01 AM
PID loop sample rates and resolution arvidb General Electronics Discussion 10 11-12-2004 05:09 PM
Brushed vs Brushless Swede General Electronics Discussion 7 09-07-2004 12:01 AM
AC Brushless vs DC Brushless h3ndrix General Electronics Discussion 5 03-25-2004 09:29 AM
Pid Swede General Electronics Discussion 1 01-04-2004 01:22 PM
