Old 04-05-2009, 10:57 AM
Gold Member
Bobbyr70 is on a distinguished road
Fenner Drive out put to motor
Have a question about some older DC servo drives.
I am retrofitting a Lagun that had an Anilam crusader controler on it with baldor dc servos. I have salvaged the motors and power supply and purchased Larkins Viper 200 drives to power the servos.
One thing I notice is the old fenner drives, used some Coils (like a power supply transformer)(for lack of a better term) in series with the motor output. What is the purpose of the coils? Would they serve any useful purpose in the same place with the viper drives? the reason I am asking is because I also aquired an older servo dynamics drive chasis, and it too has the same coils on the motor output. I plan on using the chasis, being it is pretty clean and some wiring is in place and neat.
Old 04-05-2009, 11:10 AM
Al_The_Man's Avatar
See if this is what you are referring to, from Post #17 on.
http://www.cnczone.com/forums/showth...t=76055&page=2
Old 04-05-2009, 12:49 PM
Gold Member
I am assuming you are refering to the armature chokes in the post.
What exactly does a choke do for a servo motor? reduce current? Reduce voltage? What are the benifits?
Will I need this on the output of the Viper drive? I think I will also contact larken about this too. What are your thoughts?
Old 04-05-2009, 12:52 PM
Gold Member
Yes that is exactly what I am refering to ( I see the pic on 17 now)
Old 04-05-2009, 02:00 PM
Al_The_Man's Avatar
I believe the poster in the link was also using Viper driver, see post #42 on the same link for the reason for them, I have always tended to keep them, they have the effect of lessening large current spikes through the motor.
Being an inductive device, they offer very little or none opposition to DC or current of a slow changing nature, but offer impedance to a very fast changing signal.
Old 04-05-2009, 03:15 PM
Gold Member
I will leave them just like they are, and use them. It can't hurt. Thanks,
Old 04-26-2009, 01:09 AM
paulsand is on a distinguished road
Bobby,
I am trying to convert a crusader M to a Galil 1830 motion card through a ICM-1900 breakout board. for the servo drives do you know what wires go to witch terminals on the breakout board? I can send pictures and diagrams.
how can i contact you?
Paul
[IMG] code is Off
Need tech data Fenner/Servo Dynamics SFD1525-12 calmissile Servo Motors and Drives 2 04-30-2010 03:33 AM
just installed teh new motor drive, but?? johnh Tormach PCNC 3 02-06-2009 10:13 PM
Fenner M-Drive pzzamakr1980 General Electronics Discussion 5 09-11-2008 06:03 PM
Simple, 3 Axes with Dual Drive/Motor (per axis), hardware splitter drive Interface. kreutz Stepper Motors and Drives 3 07-03-2008 06:57 PM
What motor drive for an arm? nervis1 RC Robotics & Autonomous Robots 9 12-16-2005 02:30 PM
