Old 01-09-2005, 01:42 PM
CNC Darren is on a distinguished road
Question Need alittle help with motor rating
hi all,
I have a bunch of these motors http://www.nisca.co.jp/motor_eng/dc_nc5475.html
and would like to know what the oz/in rating is but i'm not sure how to convert the listed rating to oz/in. I am planning on using these on a smaller table, probably around 24x48 and want to make sure they will be strong enough. I do have several so could I use more than one motor on each axis and connect them with a timing belt drive? Not sure how i would mount the encoder then tho as it would only be on one motor. I'm new to servos and am looking at rutex for the controler.
CNC Darren
Old 01-09-2005, 01:58 PM
wile_e's Avatar
wile_e is on a distinguished road
Originally Posted by CNC Darren
hi all,
CNC Darren
1 oz = 0.0283 kg
F = m*a
g = 9.81 m/s2
1 oz ~ 9.81*0.283 = 0.278 N
1 in = 0.0254 m
1 oz*in = 0.278 * 0.0254 = 0.00681 N*m
http://www.cnczone.com/forums/newrep...reply&p=59604#
cheers
Why can´t Americans learn to use SI units like the rest of the world? http://www.cnczone.com/forums/newrep...reply&p=59604#
Roll Eyes (Sarcastic)
Smilie
Old 01-09-2005, 02:00 PM
wile_e's Avatar
Sorry, but my ironic but well intended smileys did not come out the way I thought they would... :-(
Old 01-09-2005, 02:12 PM
Al_The_Man's Avatar
One mNewton = .001 Newtons. To convert Newton-metres to ounce-inches multiply x 141.612.
So if motor is 147mN/m .147x141.612 = 20.8 oz-inch.
Does that look right?
Also you would be better off looking for the right size single motor rather than trying to parallel servo motors.
Al
Old 01-28-2005, 03:09 AM
whiteriver's Avatar
whiteriver is on a distinguished road
I think i attached a image. This motor says trq (stall) at 6Nm. Thats really not much if i figured right.53.1045 in/lbs. 850 oz/in i think. For such a big motor it sure don't push much. Do servos do more with less than steppers? My steppers on my router are 2600+ oz/in and the motors are allot smaller than these 3 phase servos.
Donny
www.whiterivermfg.com
Name:	fanuc ac servo spec.jpg‎
Old 01-28-2005, 05:00 AM
arvidb is on a distinguished road
Servos keep their rated torque up to nominal speed, while steppers drop off in torque with increased speed.
Arvid
Old 01-28-2005, 09:43 AM
Swede's Avatar
Swede is on a distinguished road
Download CONVERT.EXE and all these pesky math issues will vanish. Look in the download section of the Zone!
N*M to Oz/In no probs!
Old 01-29-2005, 09:44 AM
Oz/In, 147mN/m
Torque is force times distance, not force per distance.
Think about opening a door: if you pushed directly on the hinges instead of the handles, and if torque were force per distance, the resulting torque would be infinite (distance = 0) and the door would smash open in an infinitely short amount of time - not exactly the way you would expect a door to behave when you touch its hinges.
Arvid
Old 01-29-2005, 02:47 PM
Swede's Avatar
That's why I let my computer do that kind of stuff!
[IMG] code is Off
