| Servo Motors and Drives Discuss servo motors, drivers and other related topics here. |
I Have built a home cnc router with stepper motors, I now want to build one using DC servo motors, the ones that I am looking at are the NEMA 34 dc servos from kelinginc.net. My question is, does anyone know if I can use these buy just hooking them up to my lead screws direct (like my stepper motors) or will I need some type of Gearing to have smooth operation at slow speeds? Thanks, Tom |
| NEMA size rating does not indicate torque, just mounting frame size, if you use the correct size motor for the application, servo's are quite capable at low rpm's. Like steppers, servo's have maximum torque at zero rpm. I generally use 1000cpr encoder, which x4 using a .2 lead BS, gives 20,000 counts/inch. I can position to within one count error. Servo's are capable of being geared high, this allows an economical sizing of the motor due to the high rpm capability of a servo and still maintain torque up to the max. rated rpm. Al.
| Yes, essentially you should. Al.
| Slow axis speed | Aaronem | DIY-CNC Router Table Machines | 1 | 02-10-2009 05:29 PM |
| Problem- Slow Speed Stalling? | bigz1 | Stepper Motors and Drives | 2 | 04-20-2008 02:15 PM |
| Help. Slow speed | shamus13 | Mach Mill | 2 | 12-08-2007 11:06 AM |
| Slow down the pneumatic actuator speed | Syphonics | Mechanical Calculations/Engineering Design | 3 | 12-21-2006 10:21 AM |
| Cut speed is stuck at Slow????Mach 2 | mwalach | Mach Mill | 3 | 08-24-2006 06:58 AM |
