Old 02-25-2009, 04:17 AM
fidia is on a distinguished road
Servo Motor Characteristcs
Hi I am trying to get actual values for the acceleration of servo motors for a college project i am doing on cnc programming. I am trying to get data on the acceleration times of various servo motors.
Old 02-25-2009, 09:10 AM
Al_The_Man's Avatar
Are you trying to obtain Manuf. specs or want to obtain the results of a particular motor empirically?
You could obtain the rotor inertia from the spec sheet and use a zero load using one of the free sizing programs.
I am not sure why you would need this, as usually the acceleration rate is calculated when attached to a load and certain accel/decel rates are required, The motor size is then typically calculated for a motor to load inertia ratio of < 10:1.
Any reduction will reduce the inertia ratio by the square of the reduction.
Old 02-25-2009, 04:04 PM
I am actually doing a college project and need the spec (acceleration data) as i am writing a computer programme to estimate machine time based on motor acceleration and deceleration
Old 02-25-2009, 04:12 PM
Al_The_Man's Avatar
As I mentioned, I think that obviously this will depend on motor load and acceleration requirements (Inertia).
Down load this program, it may help with what you are trying to find out.
http://www.electromate.com/technical...morgansoftware
Old 02-25-2009, 05:15 PM
Gold Member
Mariss Freimanis is on a distinguished road
You can reasonably expect 15,000 radians per second squared from brush type servomotors.
Mariss
[IMG] code is Off
Stepper motor vs. Servo motor Tony611 General Electronics Discussion 28 11-19-2008 08:11 AM
replacement motor for PML&Kollmorgen DC Brush Servo Motor fymroger Product Announcements & Manufacturer News 2 10-24-2008 03:36 AM
Sell Servo Motor, Servo Drive by GSKcnc.com from China salecnc@hotmail Product Announcements & Manufacturer News 0 06-03-2008 02:55 PM
servo motor eloid Servo Motors and Drives 4 11-26-2007 01:37 PM
Servo motor used as spindle motor? fatal-exception General Metal Working Machines 6 09-14-2007 02:55 AM
