Old 12-02-2004, 07:56 AM
Baloo76 is on a distinguished road
Help with parameters on EG&G servomotors
Hi.
I have found four motors from EG&G with PMI encoders.
I have searched all over the net for som information of this motors. I cannot find anything.
Then I wonder if you might help with any information about it. The serial number of the motors is really hard to read but the encoders says:
Model: 00M2300040 5H
Type: M230180L4EC541/2S
Model: 00M2300040 5J
Type: M230180L4EC541/2S (Two of these)
Model: 00M2301739 9H
Type: M230180ABI12AC5000S
/Thanx, Björn
ID:	4127   Click image for larger version
ID:	4128   Click image for larger version
ID:	4133   Click image for larger version
ID:	4135   Click image for larger version
Old 12-02-2004, 10:22 AM
Al_The_Man's Avatar
These are motors also made for or by? CMC Cleveland Machine Controls although I don't have any info on 2300 series, but they look identical to the 2600 series, I have information on the 2100, 2600 and 3500 series and the series can often be determined by the diameter and the torque by measuring the length. These appear to the type without tach, but you do not need a tach if you operate them in the torque mode with encoder feedback to the control. If you let me know the dimensions I could see how close they are to the info I have.
Al
Old 12-02-2004, 11:02 AM
Measurements in inch
Axis diameter:
0.50
Axis Length
2.58
Diameter of frontring with two screws and two ventholes
2.87
Height of the same ring
0.09
Lengt from frontplane to backplane of the same
0.22
Diameter of the same
3.61
Diameter of body
3.4
Length of body
2.86
Diameter of Rotor body
2.461
Length of the same
0.93
Diameter of encoder cover
2.27
Length of cover
0.77
If you need more detail, I can make something better and mail it to you.
It should be of much interest to know the connections and signals of the encoder to.
/Björn
Old 12-02-2004, 11:17 AM
Al_The_Man's Avatar
Here is the link, you may be able to pick out the motor closest to yours, they look like 3500 maybe, if you click on the 3500 motors it should give you a PDF to download info to compare physical size which should at least give you a ball-park rating.
http://www.torquesystems.com/product_family_brush.html
I will see what I have on the encoders, How amny wires to the the encoder?
Al
Old 12-02-2004, 11:26 AM
There is seven wires.
Red
Black
Red/white
Gren
Blue
White
/Björn
Old 12-02-2004, 04:37 PM
Al_The_Man's Avatar
I do not have the pin out for these encoders, you may have to extract it the hard way, it is almost certain red is + and black is common, I would hook this up to 5vdc supply and rotate the shaft and check the output on the other wires, you may have an A & B channel with the respective complements on the the other two channels, if you have access to a double beam 'scope that would help. It does not look like you have a marker pulse (1pulse/revolution). unscrew the cover and see if you can see any IC numbers as this could tell you if it is line driver or open collector output.
Al
Old 12-09-2004, 04:40 AM
Jonas_A4t is on a distinguished road
Would these motors run with the Servodrive from Gecko?
http://www.geckodrive.com/item.htbml...0&item_id=G320
I understand that the encoders must be atleast 200ppr, could it be a working solution for a medium size X/Y table?
Im a friend of the threadstarter and he has offerd me the motors and Im not at all in terms with servomotors sins i have planed to use steppers, but the servomotors is an interesting idea!
Jonas
[IMG] code is Off
Parameters No. for file transfer on a Fanuc O-mate controller Niall Fanuc 8 06-03-2009 09:14 AM
parameters for anca 2000 hercus compulathe poppyplant Machine Problems, Solutions , Wireless DNC, serial port 2 05-27-2005 12:26 AM
Parameters Vince.P Machine Problems, Solutions , Wireless DNC, serial port 3 04-27-2005 08:06 PM
Need help with machining parameters tex G-Code Programing 4 03-02-2005 03:44 AM
Parameters on Cobra 42 Hardinge Niall Bridgeport and Hardinge Mills 0 07-16-2004 05:38 AM
