Old 01-09-2009, 07:57 PM
NJC NJC is offline
NJC is on a distinguished road
OKUMA SERVO MOTOR REPAIR ADVICE NEEDED
Hello,
I have an Okuma LB-15 with a BL-80 servo on the X axis. I was hearing a bearing sound while moving the axis. I narrowed it down to the motor itself, so I removed the servo and disassembled and found the bearing at the pulley end was shot and had spun on the armature shaft. I doesn't appear that alot of damage was done but the bearing is not snug on the shaft, it rocks a bit. No problem to replace the bearings but I need to get the shaft repaired or a replacement one. Do you guys have any suggestions on where to go for repair or a replacement?
Thanks, Scott
[IMG] code is Off
Reliance Servo needed............or repair! tgm Servo Motors and Drives 3 04-06-2012 10:12 PM
Problem- BL -80 SERVO OR REPAIR ADVICE NEEDED NJC Okuma 0 01-06-2009 07:27 PM
Repair or replacement of SEM servo motor brad white Bridgeport and Hardinge Mills 4 01-04-2009 05:44 PM
Bridgeport servo motor repair or replacement greeder88 Bridgeport and Hardinge Mills 4 02-22-2008 03:32 PM
Help! Advice needed to convert stepper to servo! designit Servo Motors and Drives 7 11-28-2005 11:35 PM
