Old 12-06-2008, 06:13 PM
John3 is on a distinguished road
Dead WestAmp Servo Drive - Mid-job, need urget help!
Hi All,
Have a WestAmp Servo Board that has two dead H-Bridge output transistors (top and bottom on the same side). They gave up the ghost in the middle of an urgent job I must finish quickly.
One transistor is Open and the other is Shorted. The other components (series diodes & Snubber parts) in the circuit test okay (except a 47ohm resistor which I can replace)
I think my quickest way to get back up and running, possibly this weekend, is to replace the transistors, but I'm not sure what they are and I don't have a schematic. I have a pretty good stock of transistors at my disposal.
Any help in identifying the parts, or diagrams or whatever, would be greatly appreciated.
The particulars are:
Full unit - six axis
Serial # B535
Model # A7216-17F-307
Buss Voltage 170 VDC measured
Axis Drive Modules: 33026-5 SN: 1724S
PC Board: ASSY 33010-1 AW33008 REV C
H-Bridge Transistors: Q501 - Q504
Labeled 29065 - 240 TO-3 case
A picture of the board is attached.
Judging from board layout, associated components and audible PWM frequency, I'm thinking that these are NPN Darlington Power Devices....
TIA,
John
Old 12-06-2008, 06:21 PM
Al_The_Man's Avatar
The info I have is for Motorola Darlington MJ11032 Q1~Q4.
I usually end up replacing the whole drives with A-M-C Servo amps.
Old 12-06-2008, 07:01 PM
Al,
Thanks for the suggestions!
My transistors might be a little beefier than the MJ11032's you mention. My Power Supply buss is +170VDC and the MJ11032 seem to be rated for only 120Vce.
But the information is helpful. I guess if Westamp used Darlingtons in other versions there's a good chance mine are too.
Do you by chance have any schematics for these animals?
What are the A-M-C boards you mention?
As always, thanks a ton!
John
Old 12-06-2008, 08:18 PM
Al_The_Man's Avatar
I have the instruction manual which has a schematic, although not in complete form, parts of it show just a conceptual block.
They do show four NPN Darlington's, however.
The boards look identical to your pic.
The drives I have used can be seen at http://www.a-m-c.com/
Old 12-06-2008, 10:07 PM
Al_The_Man's Avatar
In an H bridge configuration, would any one transistor be subjected to the full buss voltage though?
Old 12-07-2008, 04:28 AM
I would say sure, all the time, its how they work.
For instance looking at one side of an H-bridge, there are two switching transistors in series across the full bus voltage. When the top transistor is on, the bottom one sees full buss voltage across it, and when the bottom transistor is on the top one sees full voltage across it.
When you start considering dynamic braking, the voltages even go higher than the nominal buss voltage, and the buss voltage itself can rise.
John
[IMG] code is Off
WestAmp 30059 servo driver board ahmedrehan Servo Motors and Drives 43 02-01-2010 09:49 PM
Sweo spindle drive? new mill dead spindle Shizzlemah Fadal 13 12-18-2008 11:11 AM
Westamp servo board pinout help metlcutr55 Machine Problems, Solutions , Wireless DNC, serial port 1 07-01-2008 10:50 AM
westamp servo board problems ninja11zx Machine Problems, Solutions , Wireless DNC, serial port 1 01-28-2008 08:27 PM
Westamp drive manual ??????? jheiks Servo Motors and Drives 0 10-26-2006 11:00 AM
