| Servo Motors and Drives Discuss servo motors, drivers and other related topics here. |
Trying to learn as much as possible about motors...specifically servos. I'm convinced that my (to be designed) router should use servos. Figuring an aluminum gantry, with a 3.25 HP router/spindle, and a work area of about 24" by 36"...I guess I'd have to really figure out the speed and torque requirements...but maybe there are some 'general' specs we can talk about regarding DC motors: 1. What makes a DC motor worthy of being called a 'servo'? Is it just the fact that it'll spin at around 3,000RPM, it has adequate HP, and you can stick an encoder on it good enough? Or are there other specs it needs to meet (duty cycle?). 2. My "gut feel" is that for my x-axis, I'd need a hefty motor -- maybe 1/2 HP with a 1/2" or larger output shaft. Say I were to find a cheap motor like this, and it can be altered to accept an encoder, and it spins at 3,000RPM, and it likes 30 to 36VDC. Would that be something to look at, for my axis? 3. I see a lot of 12VDC motors...but I'm assuming that they just won't provide the torque needed. Usually, they seem to be for automotive applications (emissions, or blowers, etc). No good for servo adaptation, right? 4. I also see a lot of 90VDC motors, and a few 'in between' (40V to 60V). If the other specs look right (RPMS, HP), can they be used? Or, will the power supply requirements be too great? As an example, here's a motor I was looking at tonight. I think the price is kind of high...and I suppose the rear cover would have to be removed and the shaft tapped to put a smaller shaft into it, for the encoder...but in general, would this motor "cut it" as a decent servo? http://cgi.ebay.com/ws/eBayISAPI.dll...tem=5934321133 It's 50V...looks like it is well made...if I ever tripped across one similar for around $10-$15, would it be worth using? Thanks! -Chris |
| Actually, I think Ametek makes that motor in a servo version. There should be some identical ones on Ebay with encoders selling for about $150.00 each. That might be that guy's secret. Yes I think it would work just fine. One other thing to look for in a motor is timing. If the motor has slightly advanced or retarded timing, it will perform differently in forward than it does in reverse. This is very bad for a servo. Many motors made for certain applications will have their timing advanced a couple of degrees. Obviously this is only an issue with brushed motors. I think pretty much all brushless motors are servo grade. |
A motor in itself is not a servo. What turns it into a servo is the drive - a servo is just something that "serves" you; i.e. it goes where you tell it (or as fast as you tell it etc) and it also makes sure it does that by feedback. To do this it needs a drive/controller of some kind. Another difference is that a "generic" small 12 V motor is made to run at 12 V. A servo motor marked 200 V might burn if you just hooked it up to a 12 V supply! It needs to be hooked up through the drive to limit current.
Arvid |
| Thanks...your answers and Noah's helped out a lot. Funny you mentioned AC servos -- I was wondering about them, too. I was thinking there might be a way to wire up a 'standard' 120VAC tool motor (like from a 10" table saw) to a DC servo driver, by using relays to DC-switch the motor (and also to re-wire the motor from CW to CCW, depending on the direction signal). For a Y or Z axis drive, that might be silly -- but for a large router with a long X axis, maybe it'll be the answer for the required torque and speed. Anyone ever try using a 120VAC motor, driven from a DC servo driver via relays? Of course, I do recognize the requirement for an encoder, and the fact that the rotational inertia on a table saw motor might be too great for this...but I was wondering anyway Thanks, Chris |
| Woody, I use these as servos. http://cgi.ebay.com/ws/eBayISAPI.dll...tem=3844568448 As you can see they look pretty similar to the picture you have. I guess if you can fit an encoder on the back then they are the same. These servos work for me very well. You could save a lot of money if you can do the conversion yourself. I bought these servos a long time ago for 150 each. I guess if you have success with doing a conversion you will have a lot of others following you. |
| There is nothing that differentiates a cheap little 3-commutator segment toy motor from a sero motor except quality. The former is completely unsuitable for servo use because of torque ripple while a good quality utility motor may qualify. Torque ripple is how much does torque change as the motor rotates over a revolution. Servo drives are tuned to a motor's torque response. Ideally they expect the same torque no matter what clock position the motor is at. With cheap motors this varies a lot. With excellent motors it varies very little. Cheap motors can never be tuned, good ones tune easily. What makes a good motor? A lot of commutator segments and a skewed (spirally twisted) low-cog armature. Brushes that are not preferentially set for a particular direction. The range of motors from the cheapest to the most expensive is a spectrum. Pass a certain threshold and a utility motor can be a good servo motor. Mariss |
BTW, my goal is to use Gecko's, so I want to stay within the proper specs as I search out my motors. Regards, Chris |
#10
Now what I'm thinking of, is if, until I get the Gecko's. Can I get a Xylotex stepper driver board to control relays that will control these bigger wiper motors using a 20A regulated power supply (for the motor) or is there a better way? Using this board, do I need a certain circuitry to accurately control the voltage (cut-off/vent to another load the residual voltage if there's such a thing) from the relay to the motor? Or forget it and just use the Geckos. I, as most here, am just trying to find an alternative way of doing homebrew CNC with readily available components and surplus wiper motors are sure abundant in auto parts recycling facilities. Thank you for responding. EC |
#11
The DC motors used in cars are often high current intermittent duty with sleave bushings instead of bearings. If gears are involved there will most certainly be hugh amounts of backlash making them unusable for any type of postional control. Modern servo controllers (Gecko's) close the loop inside the control. They will "dither" one or two encoder counts. If the encoder is not on the primary motor shaft then any system backlash is inserted into the loop equation. It's like driving a car at 60MPH with a really loose steering box and trying to stay within 1 " of the center line! If you just want to build a machine that moves under computer control than using low precison parts is an option. If you want the machine to be useful beyond showing your friends, then you need to realize that some parts need to be of higher quality. There are good DC motors that can be used with encoders as servos. They typically are rated for the continuous duty under load you will subject them to and have the torque and RPM that work with good CNC designs. Almost all servos need some form of speed reduction since they spin faster than steppers. Most designs use the toothed belt- pulley approach. The smaller the amount of backlash you can have in a system the better. Using rack and pinion drive a direct coupled servo will produce astounding rapids at really low torque. Leadscrews can help since they act as reduction at the TPI of the screw but can also introduce addtional errors and backlash. Just hooking up some DC motors and a direction relay to control motor direction would not get you close to anything that would provide positional control. Do a little more investigation into the Hobby CNC controls and read this list and look at some of the projects and how they were done. There is no substitute for experience (:-) |
#12
Servo types will generally have 4 brushes, many pole windings and skewed rotor windings to eliminate low speed cogging. Al.
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| Using surplus servo motors as spindle drive | Swede | Servo Motors and Drives | 11 | 03-16-2008 09:05 AM |
| Italian MAE Servo Motors?? | powerfade | Servo Motors and Drives | 2 | 02-20-2005 11:06 PM |
| 3 servo motors - What are the actual specs? | Bloy2004 | Servo Motors and Drives | 10 | 06-10-2004 02:36 PM |
| General electric servo motors wanted | Rich Monfo | General Electronics Discussion | 2 | 04-07-2004 04:05 PM |
| New Contest WIN SERVO MOTORS!!! | CNCadmin | CNCzone Club House | 83 | 07-18-2003 03:16 AM |
