| Servo Motors and Drives Discuss servo motors, drivers and other related topics here. |
from a Camsoft / Galil setup. I'm replacing the servos and drives with sureservos. so far i am having trouble getting signal to the drives. the servos jog thru the drive unit but are not responding with the signal from the galil. Thanks so much! |
| Check to see if you are getting the ±10vdc at the drive, or at least some analogue voltage. I like to tune and test using the Galil Terminal direct first. Why are you using step/dir with galil? or are you using the stepper output? Al.
Yes, the previous setup was setup as step and direction. so i thought i would do minimal disturbance so we could get the machine up. I am getting a signal from the galil. i think i must be missing some servo enable or other limit type error stopping it from responding. do you know which inputs are required? the drive has a servo enable mode and even when its enabled it does not respond. |
| If the drives take ±10vdc I would set them up that way from the Galil, if you command a move, you should see the analogue output on the motor command output. Use the DMCTERM or equivalent from Galil to get the motors set up with the native commands first. Al.
| Step or Direction? | ardor | Viper Servo drives | 3 | 07-25-2007 03:04 PM |
| Driving two step motors off one drive | Davidh | Stepper Motors and Drives | 2 | 10-23-2006 01:55 PM |
| Step and direction software | bgolash | Gecko Drives | 2 | 12-04-2004 12:29 AM |
| step in what direction | craftech | Stepper Motors and Drives | 5 | 10-13-2004 05:45 AM |
| Step and direction source | pauls | Gecko Drives | 1 | 09-03-2004 07:19 AM |
