Old 11-07-2008, 03:42 PM
stokesy202002 is on a distinguished road
vibrating x axis servo motor
My Fadal 15xt has developed some quite aggressive vibrations when moved in the x axis. Its worse moving in the x plus direction.
I have detached the motor from the table and jogged using the hand wheel, it sounds to me like the bearings within the motor have gone. when the motor is running its not a constant rough sounding vibration, sometimes it can complete a couple of revolutions smoothly before it starts knocking and sounding rough.
I have had a price for repair at around £500 ($900).
Would like to know - if its a matter of changing the bearings can i do this myself as a complete novice ?
Rob
Old 11-07-2008, 03:58 PM
Al_The_Man's Avatar
In some cases electrical sourced vibrations can sound mechanical, I would try to eliminate a few things first.
Is this a DC motor and is it ±10vdc analogue drive?
If the above, I would take a close look at the tach if it has one, also it would help if you disconnected the analogue input and attached a ±9vdc battery box. It is simple to mock one up.
You can move the motor this way disconnected from the controller.
Does the motor feel rough when you turn it by hand?
If it turns out to be the bearing, they can be replaced relatively easily, remove all brushes and take the end plates off, careful when removing the armature as it will attach itself to the field magnets.
Some have said they have lost field magnetism when removing the armature, I have not yet experienced this, but if in doubt, slide a metal 'keeper' into the field as you remove the armature.
The commutator may need skimming and undercutting when you have it out, undercutting is using a special thin saw blade to clean the mica, or? from the comm. segments.
One can be fabricated from a ground down hacksaw blade.
Old 11-12-2008, 03:00 AM
macona is on a distinguished road
Your gain setting may be too high on the drive.
Old 11-12-2008, 12:19 PM
JonLed is on a distinguished road
I would try swapping the x and y drives to see if the problem moves with the drive or stays with the motor.
Jon
Old 11-14-2008, 08:17 AM
Thanks for your advice guys,
I ended up taking it for repair, they skimmed and undercut the commuter and seems to have done the trick.
Rob
[IMG] code is Off
Need Help!- X Axis Servo Motor Overheat mtgpaul Colchester Tornado lathes 5 10-17-2008 07:37 PM
Need Help!- Servo motor for Lathe & 4th axis skip20 Mini Lathe 6 04-16-2008 10:02 AM
I need links on how to assembly a servo motor controller for my cnc 3 axis router rodjava DIY-CNC Router Table Machines 2 02-22-2008 11:02 AM
Fadal axis servo motor apart and we have issues Houston carbidecraters Fadal 5 11-04-2007 12:41 PM
There is this faint vibrating/hissing/humming feels to my stepper motor. Why? alexccmeister Automation Technology Products 9 05-20-2007 07:45 PM
