Old 11-04-2008, 11:10 PM
Konstantin's Avatar
Konstantin is on a distinguished road
Understanding encoders.
Hello.
In ABZ encoders the Z is also called "index" ?
Konstantin.
Old 11-04-2008, 11:26 PM
Al_The_Man's Avatar
Z, Index, Marker are a few terms used for the same thing.
Old 11-04-2008, 11:27 PM
Konstantin's Avatar
Thanks Al.
You are always so helpful.
Konstantin.
Old 11-05-2008, 09:35 AM
Andre' B is on a distinguished road
I have also seen the term grid used. Imagine as the machine moves X,Y mill or X,Z lathe the index pulses define a 0.1", 0.2" etc. grid over the travel.
Old 11-05-2008, 09:47 AM
Al_The_Man's Avatar
Originally Posted by Andre' B View Post
I have also seen the term grid used. l.
True.
And many systems will offer a software parameter that will move the grid, (Grid Shift).
This will effectively move the marker pulse in encoder counts so the home position can be precisely lined up with a tool changer etc.
This eliminates the need to turn the encoder manually to try and line up the marker.
[IMG] code is Off
using and understanding mach3 D CUSTOMS Bridgeport and Hardinge Mills 1 06-12-2008 09:13 PM
GD&T understanding problem fsa Mechanical Calculations/Engineering Design 4 04-23-2008 04:57 PM
Understanding Plasma THC nerginer CNC Plasma and Waterjet Machines 10 09-12-2007 04:33 PM
Understanding G-code ... or not! geoff p G-Code Programing 4 01-01-2006 01:46 PM
Need help with driver understanding ArtistEd General Electronics Discussion 2 02-07-2005 09:34 AM
