Old 11-03-2008, 10:50 AM
Konstantin's Avatar
Konstantin is on a distinguished road
Help with encoders for Logosol LS173 drives
Hi all.
While attempting to test a LS173 Logosol drive I see that the connector for the encoder has A,B,Z, +5 and GND.
From my junk I have found some encoders but they all lack Z.
I haven't used those encoders yet, I thought I'd better ask before.
Will the LS173 work if it lacks Z from encoder?
What encoder could I use for those drives, assuming its a 250cpr.
Konstantin.
Old 11-03-2008, 11:42 AM
Al_The_Man's Avatar
It should be OK, it is just that you will lose a home to marker feature, if it is differential encoder input, tie inputs Z high and /Z low.
Old 11-03-2008, 12:08 PM
Konstantin's Avatar
Al thanks for the quick reply.
I am a bit confused about what to tie up.
Here is the "Encoder and Commutator" pinout of the drive I have:
1 GND
2 ENCODER Z
3 ENCODER A
4 +5V
5 ENCODER B
6 +5V
7 COMMUTATOR S1
8 COMMUTATOR S2
9 COMMUTATOR S3
10 GND
Konstantin.
Old 11-03-2008, 01:57 PM
Al_The_Man's Avatar
You may not need to pull the single ended Z up if it is not used.
Everything else needs connecting.
Check continuity to see if 4 & 6 are connected, and the GND (commons) are connected internally if so you could just input one supply for both, if separate you could still use a common 5v supply
[IMG] code is Off
Need Help!- Looking for Logosol - FlashCut Servo Drive ponthieux General CNC (Mill and Lathe) Control Software (NC) 0 08-20-2008 08:33 AM
Encoders ramasule DIY-CNC Router Table Machines 3 12-24-2007 12:27 PM
Can someone help me with these motor/drives, I think the drives are dodgy? Darc Stepper Motors and Drives 1 07-23-2005 06:31 PM
Servos, steppers, drives and encoders, Oh my MobilDave Servo Motors and Drives 1 09-10-2004 07:04 AM
servos (encoders, drives) gv71 General Electronics Discussion 3 03-31-2004 12:43 AM
