| Servo Motors and Drives Discuss servo motors, drivers and other related topics here. |
Hi all, I've seen Gecko drives for DC Servos and many other peoples drive hardware. I've just started to look at AC drives and hit many bumps with ebay. 1). Most of the drives on EBay I can't seem to find info. on, even at the mfg. homepage? 2). Whats the difference between an AC Servo Drive Amplifier and AC Servo Drive Controller?? 3). All I want is step/dir. control and most of these things seem like weighty beasts with simple push button controls but no i/p for step/dir.? 4). Can I mix and match motor with drive/amp? (So long as I match voltage and current requirements...) 5). Any out standing AC drive control products which I should be looking out 4? Many thanks, Ping |
2/ AC Servo Drive & Amplifier usually indicate the same thing 3/ See 1/ There are many types of AC servo drives, if you want step & direction I believe you want the PWM type, these work with digital controllers and use a TTL input for PWM & step and direction. There are usually many of the above makes come up on eBay regularly. Al
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| 4. Not necessarily. Some drives can be configured only for a limited range of motors from the same manufacturer. Others can be configured to any motor as long as you have enough data on the motors, and they match. Only bid on an AC BLDC motor and controller after you have found the user manual, read it, understood it, and have determined they are suitable for you. Some drives are special purpose and not suitable for what you need. In some cases the same drive comes in different flavours (block controller, electronic gear, electronic cam, speed controller, ....) It's a jungle, be sure you have a machete and know how to use it. |
It's a big subject and hard to give general answers. A majority of used drives will take an analog control signal. Step and direction is not as common. Here is something I posted on cad_cam_edm_dro recently: This was about some motors that had halls and encoders, if you find matching motors and drives, that's great.
| Compatibility question (newbie) | Jan-Roger | DIY-CNC Router Table Machines | 13 | 10-07-2008 09:21 AM |
| Newbie, Which Controller (Kits) can handle big CNC accurately ? step or servo ? | Calico | General Electronics Discussion | 3 | 05-28-2007 06:44 PM |
| Newbie question: how do I machine this? (Drawing attached) | Aegeon | General Metalwork Discussion | 20 | 12-04-2005 02:20 PM |
| Newbie Servo Drive Question? | chas | Gecko Drives | 0 | 03-31-2005 01:02 AM |
| Another which should I get Servo or Stepper Question. | mysterious | General Electronics Discussion | 31 | 04-05-2004 01:02 PM |
