Old 10-27-2004, 10:55 AM
DAB_Design is on a distinguished road
Specs on an industrial sized servo
At work the other night, I wrote down the specs of the X axis servo motor on the machine I run. Rack and pinion on both X axis ways.
Stall Cont - 40RMS amps 44.8 Nm
Stall Peak - 148.6RMS amps 126.1Nm
Volts - 230 Rated RMS
Max Speed - 3050RPM
This was all that was on the spec plate on the motor. The machine is capable of 200ipm in X and Y and 60ipm in Z. The motor is connected to a gear box, but I have no idea of the ratio.
Nm is a torque rating right?
Here's a bad picture of the machine http://www.premac.com/images/532.jpg . We were cutting the parts pictured.
3 spindle/5 axis 60hp spindles @ 30" centers
Table 120" wide by 1,440" long.
X Axis = 1,332" travel.
Y Axis = 68" travel.
Z Axis = 28" travel.
Z Axis = 33" clearance
A & B = +/-25.0 degrees of travel
Standing under the machine when B is tilted over 25degrees really makes you appreciative of the safeguards taken to ensure it won't over travel and fall.
Old 10-27-2004, 11:36 AM
Bloy2004's Avatar
Fumbling Machinist
Bloy2004 is on a distinguished road
What type of gearbox is used? I know it would be humungous on that machine, but I'm looking for the "right" gearbox to drive my smaller racks on both sides and want to avoid introducing play through it. Of course the gearbox I am seeking is of a much smaller scale.
Hopefully I will keep the racks high with the gantry arms short, but having the table low with high frame sides supporting the rails and racks. Kinda like a recessed table. A hollow thru-shaft right angle gearbox is desired to lock onto the rack's pinions cross-drive shaft and would travel with the gantry.
Please tell me more about the gearbox....
For my system I figure I will need about a 25 to 1 ratio through the gearbox.
Travell will be about 3.5 feet for X and 3 feet for Y. Z travel I would like to keep around 12 to 18 inches and have an insert to raise table levels for more precise close/flat machining or routing.
John
Old 10-27-2004, 01:58 PM
Sorry, but I don't have any info on the gear box. The only thing I can say is that the motor is mounted so that it is parallel with X axis. So there has to be some type of gearing that transfers the force 90 degrees.
Don't think I'll tear into the gear box any time soon. I kind of need my job.
Old 10-27-2004, 05:05 PM
Bloy2004's Avatar
Fumbling Machinist
I'm sure many would like to see many "clear" photos of the machine you work with. If you will be taking more pictures, could you get a detail one of the gearbox? ...hint, hint, hint.
Old 10-28-2004, 06:57 AM
arvidb is on a distinguished road
That's one big servo motor. With those specs, the continuous mechanical output power is somewhere in the range of 10-15 kW! Peak 25-40 kW!
Arvid
Old 01-02-2005, 12:52 PM
Sorry it's taken so long. Fitrst two are of the control.
ID:	4419   Click image for larger version
Old 01-02-2005, 12:54 PM
next three are the gear box. pack of smokes for size referrence.
ID:	4421   Click image for larger version
ID:	4422   Click image for larger version
Old 01-02-2005, 12:56 PM
next ones are of the rack and then just some blurry shots of the machine and some tools we use on the job I was working on that night.
ID:	4424   Click image for larger version
ID:	4425   Click image for larger version
Old 01-02-2005, 12:57 PM
oops forgot one
Old 01-02-2005, 01:48 PM
Al_The_Man's Avatar
Looks to me like a worm and pinion gearbox setup. they are not usually noted for their precision, unless the encoder is on the rack.
(Cincinnati Milacron?)
Al
  #11   Ban this user!
Old 01-02-2005, 02:13 PM
Al
Yep. I'd say 95% of our machines are made by them. And all machines that are in use, except 1 (that I can think of) use Cincinnati controls.
  #12   Ban this user!
Old 12-28-2006, 11:35 PM
meckardt55 is on a distinguished road
The service men from CNC Machine Services, Inc. travel all over the world from our location in Michigan U.S.A. We specialize in Cincinnati Milacron machines, and service all other type of machines also. If you are in need machine repair, or laser calibration, and certification of your machine, please give us a call at 248-391-2341. You can also look us up on the web at cncmachineservices.com
Mike Eckardt - President
[IMG] code is Off
Specs on this servo JRoque Servo Motors and Drives 3 10-16-2006 09:26 AM
servo motor specs and help cowanrg Servo Motors and Drives 3 06-11-2005 07:11 PM
Servo Specs... CarveJunky Servo Motors and Drives 4 05-31-2005 09:03 AM
Where can I find Detail Specs Servo & Drive MEans ? Calico Servo Motors and Drives 1 02-28-2005 12:37 PM
where to get servo specs. miljnor Servo Motors and Drives 7 02-26-2005 02:39 AM
