| Servo Motors and Drives Discuss servo motors, drivers and other related topics here. |
Hi i have 2 glentek 26inch pound servo motors with 200v rutex drives on a bridgeport series 1 . My motors call for around 120vdc i was wondering if i run them at 67 volts for now will i have alot of problems loseing position and loss of power . or will i just lose my top speed. just wondering if i could run this for awhile till i can get a bigger power supply. just wondering if i will lose position and power? or will i just lose top speed Thnaks John |
| You will lose maximum rpm, and if there is insufficient voltage to deliver the required current you will experience loss of torque. Al.
| I agree with Al and it has been said before, amperage is torque, volts are speed to generalize a little. If the motors can pull the amps from you power supply you will not loose any torque, but you may be way down in speed. It will probably be right around half of max speed. I would try it with what you have and then if it doesn't work the way you want you can always upgrade the power supply. Mike
__________________ Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out. |
Hi John, I got lucky and picked up 4 brand new SEM servo motors ,on ebay,that are a perfect match for my machine. I paid like $25 each plus shipping. If you know what you are looking for Ebay can be a great place to search.
| My big mill with the sem servos goes 200 ipm on the z and only 75 on the y because the y motor is on its way out. My small mill only goes 10 ipm because that is as fast as the drives will push my motors. So I guess what I am saying is to set the speeds to what the motor will do, not what you would like it to do. I found this out by trial and error on my machines. Mike
| Is my voltage too high for motors? | johnt | Stepper Motors and Drives | 3 | 12-10-2007 02:11 PM |
| Stepper Motors and Voltage | stuart76 | Stepper Motors and Drives | 5 | 06-09-2007 07:29 PM |
| Over voltage on ametek motors? | DennisCNC | Servo Motors and Drives | 3 | 03-27-2006 09:11 PM |
| HOT motors. Voltage problem ? | DJ Morrow | General Electronics Discussion | 3 | 11-24-2005 11:41 PM |
| what voltage? i'm confused.. Stepper motors + driver board from hobbycnc | Loterus | Hobbycnc (Products) | 8 | 01-26-2005 07:10 AM |
