Old 10-05-2008, 10:41 PM
cnc2 is on a distinguished road
Question Rosemount Aerospace electric motor
Hi everybody !
I need some help about this motor:
http://www.nw-intl.com/IMAGES/p2311m51-1.jpg
I've found it on a wrecked airplane and it's a bit different from the pic as it has a second mounting plate on it.
Motor info:
P/N: 2311m-51-4
HP: 1/8
RPM: 11800
Volt: 28
Amps: 6.2
Cycle: DC
And it turns clockwise, even if i reverse the polarity.
It's a DC motor but it has three wires on it.
So, my questions are:
1) Is it possible to modify that motor to make it turn CW & CCW ? (and how?)
2) Do you think it's a permanent magnet dc motor ? (or what kind of motor is it ?)
3) Very Unprobable but who knows: is it possible to convert it to a servo motor by adding an encoder (for uhu) ? (do you think it will be controllable ?)
4) 1/8 HP 11800 RPM is it enough for a small spindle ?
Thanks !
cnc2.
Old 10-05-2008, 11:22 PM
Al_The_Man's Avatar
It is likely that two wires are motor supply and the third a ground.
The fact it is such high rpm, suggests a series motor, i.e wound field.
to reverse the polarity the field will have to be reversed WRT the armature.
If series, not much good for CNC applications.
Old 10-05-2008, 11:50 PM
Thanks Al, that was fast !
I want to add that to make it spin i've plugged two wires one at (+) the other at (-) and the third wire was unplugged ,what's the difference between ground & (-) ?
So i'll try to use it as a small spindle for wood engraving or pcb milling ...etc
Regards,
cnc2.
Old 10-06-2008, 07:46 AM
Al_The_Man's Avatar
Yes you could use it for engraving or similar operation.
If one wire is in fact ground, there will be continuity to the case.
-ve is the power supply common, it is not necessarily at ground potential, unless the application calls for it.
Old 10-06-2008, 03:40 PM
Thanks for your help Al !
Best regards,
cnc2.
Old 10-13-2008, 06:09 PM
Arrow
Hi everybody !
I finally opened the motor and found it has windings instead of permanent magnets (Al was right ;-) and also found the third wire was coming out of a switch (interupter) that opens and closes at a certain amount of motor shaft turns (you can say aprox one "tic" per ten turns) and the voltage on the third wire goes from around 3 V to 0 V at each "tic" and goes back to around 3 V.
So, is that a tachometer ? and how can it be used ?
Is there a way to (or a controller board) to control this motors speed ? (for "rigid" tapping for exemple, i know it won't turn CCW, even if i have to remove the tap manually, should be ok for hobby use)
1/8 HP at 11800 rpm, is it enough as a spindle if geared down trough timing pulleys, can it give me 1 HP at 1475 rpm ? for comparison, can it be as powerful as an X1's spindle or as an X3's ?
Thanks !
cnc2.
[IMG] code is Off
Newbie- Homemade 3-phase electric motor kadora General Electronics Discussion 20 10-21-2008 01:53 PM
Question on shimming electric motor LewisCobb General Metalwork Discussion 4 06-28-2008 11:47 PM
Most efficient electric motor? DennisCNC General Electronics Discussion 2 06-10-2008 11:14 AM
fuji electric ac motor driver camay General Electronics Discussion 0 05-03-2006 04:57 AM
Electric motor question bbergami WoodWorking 21 01-29-2006 07:07 PM
