Old 07-08-2008, 04:41 PM
knguyen is on a distinguished road
Shinano Kenshi servo motors
Hi guys,
I am a newbie and have tons of questions regarding servo motors since I have recently acquired a couple of DC servo motors from Shinano Kenshi. They came with all the cables chopped off. I guess I have to get an appropriate drive for the motor and try to re-establish the cable connection. The spec of the motor is shown in this link:
http://www.shinano.com/xampp/docs/Se...ies%20LA52.pdf
Any input and advice is greatly appreciated.
What kind of drive available for these motors? What else do I need to get them work again? Thanks in advance
Khan
Old 07-08-2008, 05:08 PM
Al_The_Man's Avatar
They appear to be DCBL, DC brushless motors, there are many drives to pick from with analogue control A-M-C, Copley etc, if you intend using step/direction control, then there are fewer drives to pick from.
If the drive does not include a power supply then this would also be required, for multi drive system, usually a single DC supply is used.
Old 07-08-2008, 06:34 PM
Thanks Al,
Already good info you provided. I looked thru AMC web site. Looks like there are many different drives , analog and digital. What to choose? I would need some specific recommendations since I have no idea on how to go about it. I would figure a drive that matches the required voltage and amp for the motors. These drives have to be somehow connected to a PC for programming? I intend to control direction of the motors as well as the rpm, so would that be done with a basic drive or something fancy? I apologize for being so clueless.
Old 07-08-2008, 07:24 PM
Al_The_Man's Avatar
First you have to decide what type of control you intend to use, this will decide the drive signal requirements.
[IMG] code is Off
Pluto Servo - Motors won't servo correctly???? TZak LinuxCNC (formerly EMC2) 2 01-10-2008 02:34 PM
DC motors as servo motors Doug Schwochert Servo Motors and Drives 5 12-26-2007 12:03 PM
How to id wires coming from Shinano Kenshi STH-55D113 stepper motor? angelhut Stepper Motors and Drives 0 10-14-2007 08:27 PM
stepper motors or servo motors? jprobst Torchmate 3 07-13-2007 05:37 PM
shinano kenshi stp-58d 106 info smeghead Stepper Motors and Drives 4 12-14-2005 10:51 AM
