  #13
Old 08-22-2005, 11:09 PM
Moderator
machintek is on a distinguished road
I have two suggestions. Try EMI-INC.net to see if they have options for you and Electrical South to see if they can repair or have a repaired board.
George
  #14   Ban this user!
Old 08-24-2005, 12:04 AM
Jonp is on a distinguished road
Vebers, if you have more than one machine try substituting parts, boards from one into the other and try to get one working. Electrical South has, will fix boards but expensive. A maintence manual is a must have, board level repair isn't too hard if your into electronics. There are a brazillion things that can keep these machines from running properly, but when working they are sweet. The tool changer and servo motors make them productive little buggers. A lot of there problems are mechanical, good luck
  #15   Ban this user!
Old 08-24-2005, 09:17 AM
vebers is on a distinguished road
Thanks for the reply's fellas. I will have to try to have some of the boards repaired or repair them myself. Unfortunatly it is the same boards in both machines so I can't rob Peter to Pay Paul. The XTC, the board in the operator interface in both machines, and the LS-1 Board in one of machines are the boards with the tell tale signs of heat. Thanks again
Vince
[IMG] code is Off
Bridgeport BTC 1 Builder Bridgeport and Hardinge Mills 24 05-17-2008 11:40 AM
Servo Motor Running away. murphy625 CamSoft Products 38 02-27-2005 01:08 PM
Bridgeport Retrofit Using Brushless AC Servo Motors? Eric Servo Motors and Drives 6 12-05-2004 09:58 AM
steppers or servo drives mmjpotter Gecko Drives 14 03-30-2004 02:56 PM
