Old 05-13-2008, 06:53 PM
kmcwhq is on a distinguished road
quality motion control, new ulm,mn
Apparently Quality Motion Control does not exist any longer.
I have motors of theirs on an old Omniturn gang tool lathe, and need pinout information......
Any idea what happened to them?
dk
Old 05-13-2008, 06:58 PM
Al_The_Man's Avatar
Is that a DC or DCBL motor? do you need the encoder pin out?
Old 05-13-2008, 07:42 PM
It's brushed......I really need all the pins.
Not sure if there's a tach or not....
dk
Old 05-13-2008, 08:35 PM
Al_The_Man's Avatar
Usually DC brushed are the easiest to reverse-engineer as regards the armature and Tach, then it may have resolver or encoder and sometimes a thermal OV.Temp switch,
Encoder or resolver takes a bit of extra effort.
What is the reason for wanting to know, a retro-fit or?
Old 05-13-2008, 09:26 PM
yea.......omnicrap control gone.....Fagor in it's place....
Old 05-14-2008, 07:55 AM
Al_The_Man's Avatar
Normally you won't need the tach if replacing the drives to modern torque mode types.
that just leaves the encoder, which may not be hard to figure out, I take it you do not have the original prints on the M/C?
Old 05-14-2008, 08:50 AM
yep.....I have AMC drives that can do velocity or torque/current mode.
I misspoke on the control name.
It was an OmniTurd, not Omnicrap.
[IMG] code is Off
Need a Quality Control inspector in Southen California ricotututi Employment Opportunity 0 01-07-2007 01:34 AM
Inspection and Quality Control in CAM Systems carla General CNC (Mill and Lathe) Control Software (NC) 1 06-10-2006 09:07 AM
