Old 04-17-2008, 09:22 PM
Patrick_v_M is on a distinguished road
TEK10 problem!
Hello everyone,
Is the someone who could help me with my TEK10 servo drives? I've got a problem when I try to let it drive my motor.
I use Mach3 to control my machine. When I give a 'jog' command, the motor turns about 1/4th of a single turn. then the drive falls into fault. after re-enabling the drive I can do the same agian.
When the motor is powered but not commanded to rotate, its is trying to hold ist position very wel. When handforcing the axis, the motor forces back. when I let go the axis (motor has no resistance anymore) it overshoots followed with an error again. Then I re-enable again.
obviously I use the: TEK10
the motors are a bit like these: (looks exactly the same on the outside)
http://www.kelinginc.net/KL34-170-72.pdf
only my data says: Nema 34 6.4 Nm 72 V Dc nom. 7.6 Amp.
encoders mounted: USdigital E5S-500-250-EG
http://www.usdigital.com/products/e5/
which are 500 cpr
Control software: Mach3
is there anyone who is familliar with connecting and configuring the Tek10 drive??
Tanks in advance,
Patrick
[IMG] code is Off
Tek10 Servo Drives On Special Kookaburra Product Announcements & Manufacturer News 4 09-26-2010 11:36 PM
machine problem or software problem? bcnc Syil Products 8 10-26-2009 09:51 AM
Teknix Tek10 VS Gecko G320 gripen General Topics 1 06-05-2007 11:01 PM
