Old 04-16-2008, 04:41 PM
markus_detroy is on a distinguished road
need help Differential Driver/Receiver circuit
need help finding Differential Driver/Receiver circuit for servo motors
anyone have any tips or links on this .
Old 04-16-2008, 05:45 PM
billyinks is on a distinguished road
found this... http://www.jensen-transformers.com/as/as030.pdf at discovercircuits, http://www.discovercircuits.com/S/servo.htm
Old 04-16-2008, 07:10 PM
Al_The_Man's Avatar
Is this question for Encoder differential driver/receiver?
As in 26LS31 & 26LS32?
Old 04-16-2008, 08:17 PM
need schematics
looking to build a diy circuit ... Encoder differential driver/receiver . for my servos, where can i get simple design,,1 or 2 or chip layout.
Old 04-16-2008, 09:29 PM
epineh is on a distinguished road
I just have the reciever schematic, can try get hold of the transmitter.
Russell.
Old 04-17-2008, 09:13 AM
transmitter
I think this the right transmitter schematic can some look it over
and see if it matches up with epineh reciever schematic
Regards
http://www.usdigital.com/drawings/pdf/
Old 04-17-2008, 10:11 AM
Al_The_Man's Avatar
Thats the same IC, both schematics show the same transmitter, you need a 26LS32 reciever, only if the controller you are interfacing it to needs single ended input.
Google 26LS32 and that is all you need.
Old 04-17-2008, 07:51 PM
i looked at both schematics one is 26ls32 other is 26ls31 both are not the same chip ??? im confussed i guess... to understand you.. your saying i only need 26ls32 circuit going from the g320 gecko controller to encoder?
please explain or show me a pic if possible.
Regards
Old 04-17-2008, 08:05 PM
Al_The_Man's Avatar
Sorry, your right, It was the way they were drawn, normally the signal in a schematic flows from left to right.
The are rec & Trans.
Old 04-17-2008, 09:02 PM
so those two circuits should work together ok.... is there any other more simplistic way of do the same thing? ie less parts?
[IMG] code is Off
Parallel L298N driver circuit help Sidco7 Stepper Motors and Drives 12 02-28-2011 09:56 PM
Servo Differential Cable Driver schematic? markus_detroy Servo Motors and Drives 1 04-18-2008 03:05 PM
stepper driver circuit.. comments? integerspin Stepper Motors and Drives 0 09-21-2007 10:27 PM
RQ: Bipolar stepper motor driver circuit elektronchika Stepper Motors and Drives 2 12-21-2005 05:29 PM
Optical Encoder Differential Line Driver azsigns General Electronics Discussion 1 03-04-2004 03:41 AM
