Old 03-28-2008, 11:02 PM
Moderator
JerryFlyGuy is on a distinguished road
Shorten the shaft of a servo??
Well guy's I've got one that I've never had before. I've got a MCG servo which has too long of a shaft. When I try and assemble it w/ my gear reducers, the pinion on the reducer won't fit all the way into the housing [it bottoms out] and there is ~1/8" of a gap between the motor and reducer flanges.
I'm tempted to take this servo over to the shop and mount it in our band saw and just take ~1/4" off the end of it.. while holding the shaft still w/ a pair of plyers..
Is there an easier/better way? I've never had to shorten a motor shaft before!
JerryFlyGuy
The more I know... the more I realize I don't
Old 03-28-2008, 11:07 PM
You could try the method I used once on a motor shaft. Wire it up, turn it on, pick up a hacksaw and use it as a kind of parting tool on the spinning shaft. Worked like charm.
Old 03-28-2008, 11:41 PM
Moderator
Now why the ^$#@# didn't I think of that? Geof to the rescue..
It must be that I'm just over tired.. yawwwnn..
Thanks man!
Jerry
JerryFlyGuy
Old 03-28-2008, 11:50 PM
Thanks man!
Jerry
Or maybe your brain is frozen with the weather we have been getting. Snow, today, in Richmond!!!!!!!!!!!!!!!!!!!!
Old 03-29-2008, 12:19 AM
Moderator
our's isn't supposed to be here until tomorrow... 200mm...
JerryFlyGuy
Old 03-29-2008, 12:44 PM
Al_The_Man's Avatar
We are supposed to get your leftovers!!
One method I have used if you have a rear shaft also, is to hold the rear shaft in the chuck and the front shaft in a tailstock centre and tie the motor body to stop it turning.
An slice it off almost all the way through.
I prefer to hold the cut end in the chuck, but you do not have much to play with.
[IMG] code is Off
Fanuc servo shaft taper angle? Jonne Fanuc 3 03-28-2008 11:58 AM
Looking for a Coupling for 1/2" motor shaft to KR33 6mm shaft DonW DIY-CNC Router Table Machines 7 03-17-2008 03:58 PM
Shorten My Endmill DroopyPawn CNC Tooling 4 11-12-2007 06:05 PM
DIY Large Bore Hollow-shaft servo motor Eric R. Linear and Rotary Motion 9 01-27-2007 08:19 AM
Hollow Shaft Servo Motor Eric R. Open Source CNC Machine Designs 2 01-11-2007 01:01 PM
