Old 03-25-2008, 05:02 PM
metalcaster4jc is on a distinguished road
Thumbs down Servo motor rebuilding
Has anyone had a servo motor rebuilt? I think that I have a tach going out of one as I get a "run away" intermittantly. The motor has all the torque necessary, and I hate to trash something that can be fixed. BTW it's a powertron 60 in-lb, 113 v servo. Is it too small to bother rebuilding?
Andrew Abrams
Marcellus Metalcasters, Inc.
Old 03-25-2008, 05:08 PM
Al_The_Man's Avatar
If indeed it is the Tach, you could try checking the brushes and the tach commutator, there is not a lot that can go wrong with a tach, it does not operate at any appreciative current.
Tach's are seldom used now, even on DC servo's, as they tend to operate in the torque mode rather than the velocity mode as yours probabaly does.
Depending on the controller, you could upgrade to a torque mode drive such as A-M-C type .
Old 03-26-2008, 06:19 AM
It is a 1981 Sharnoa controller and the run away is on the z axis both directions to the limits. Could it be a failed encoder not giving position back to the controller? Then the controller would keep increasing voltage to get the motor to move wouldn't it? Or if the driver is not proportioning the voltage?
I've had run away conditions before on the x&y axis that was casused by a faulty feed override switch ( bad contacts in the #3 position). When that happened the drivers would kick out and give me a PF error. But the drivers don't kick out with this z run away which leads me to think that it is a feed back failure.
I've been watching the postings here flro others with this controller and wanting to do an upgrade to either Ajax or Mach. Seems no one here has done it yet, or if so hasn't posted.
Andrew Abrams
[IMG] code is Off
rebuilding jgro cnc tbenefi33 JGRO Router Table Design 2 12-14-2007 07:41 PM
Rebuilding chinese laser vcosystems Laser Engraving & Cutting Machines 1 09-04-2007 05:50 AM
Rebuilding a 30 taper QC spindle bob1112 Mechanical Calculations/Engineering Design 0 11-18-2006 11:50 AM
Rebuilding a Grizzly Bender... InspirationTool Bending, Forging,Extrusion... 2 06-03-2006 06:09 AM
Rebuilding THK slides? space_case DIY-CNC Router Table Machines 2 09-13-2005 08:15 PM
