Old 03-24-2008, 06:01 PM
cnc2 is on a distinguished road
Thumbs up Maybe the end of expensive encoders for UHU servo driver board
Hi every body on the forum !
This is an encoder from a refurbished HP printer, i think it was a HP Deskjet 3500 series.
I got this fried board with the printer shaft & disc for approx 2 eur, the man told me that i can salvage the ir module because it was remaining intact.
some specs:
on the module you can read: Agilent 9985-s233. and it has 6 pins.
on the disc you can read: C8941-80004 & GMN47 & 1200CT 200LPI.
the disc is approx 5 cm dia.
After some searching on the net i think it'a an AEDS or a SEDS encoder module, supply voltage from 3.3V to 7V max.
I also got a question:
does 1200CT means 1200 count/rev, if yes is it possible to use it with the uhu servo board or is it too high resolution (my motor is 1075 rpm)?
Thanks !
cnc2.
ID:	56321   Click image for larger version
Tags
encoder, motor, servo, uhu servo
[IMG] code is Off
WestAmp 30059 servo driver board ahmedrehan Servo Motors and Drives 43 02-01-2010 09:49 PM
dc servo motors and encoders visky Want To Buy...Need help! 4 01-16-2008 08:42 AM
Q: Motor tuning. Servo/Encoders Deviant Mach Mill 5 01-10-2008 11:19 AM
CNC newbie question Servo+driver+breakout board? wolfmetalfab Servo Drives 0 05-11-2006 01:43 AM
Excess voltage to servo driver board Splint General Electronics Discussion 4 04-27-2004 03:46 AM
