Old 03-23-2008, 02:32 PM
cnc2 is on a distinguished road
Question DC Servomotor question
Hi every body on the forum !
I have a four brushed dc servomotor, the manufacturer told me it's a 290 W "useful" (i'm not sure at the translation 'cause it was in french) it's rated 42Vdc & 8.5 Amp & 1075 rpm, and he said 2.58 Nm of torque computed from the power in Watt through the formula P=T*omega, omega=(2pi*(rpm))/60.
My questions are:
1) what is the torque that is computed through that formula, the continuous torque or continuous stall torque or peak torque ?
2) Is the shaft spinning at 1075 rpm with 2.58 Nm of torque ?
3) Is the peak torque 2.58 Nm or it's much higher than this ?
4) Is it possible to increase its speed safely, and how ?
5) Is this servomotor enough for a cnc metal milling machine, does it need a speed increasing ?
Thanks !
cnc2
Old 03-24-2008, 11:20 AM
mmjpotter is on a distinguished road
cnc2
1- the rated value is usually quoted as continuous stall torque
2- Yes. 100w corresponds approximately to 1Nm at 1000rpm
3- Peak torque will be higher but cannot be mainatained for more than a
few seconds
4- To increase the speed you will need more voltage but it is not
reccommended to input more than the rated value (i.e 42 volts) as this
will cause the motor to over-heat.
5- These are more than adequate motors for must small workshop machines.
1000rpm coupled via a 1:1 toothed belt drive to a 5mm(0.2in) pitch
ballscrew will give you 5000mm(200ins)per minute traverse speed. I think
this would outrun most stepper/mach3 sytems.
MJP
mike potter
Old 03-24-2008, 02:58 PM
Thumbs up
Originally Posted by mmjpotter View Post
cnc2
few seconds
MJP
Thanks a lot man for these precise & convincing answers, but
what you mean when saying "small workshop mashines" do you assume they can mill steel with these motors & 1:1 drive, will the torque be enough for that purpose ?
Thanks !
cnc2.
Old 03-25-2008, 10:03 AM
Wink A question about dc motor torque & current
I got a matsushi'ta DC motor with tach on it, it's a 20vdc geared motor & ther's no current spec it's a GMX-7MP008A. I already posted the pics here post#1:
http://www.cnczone.com/forums/showthread.php?t=54079
My questions:
1) How to know its rated current (Amp) ?
2) It's near impossible to stop it by hand because it's geared and spins at 475rpm with 20vdc, is it suitable for a metal milling machine ?
Thanks !
cnc2.
Old 04-02-2008, 06:40 PM
Thumbs up
:UP:
Old 04-13-2008, 08:24 PM
cnctechno is on a distinguished road
hello ,
I have two servo brush motor model EG&G ME-3515-131E and do not know
the voltage and current amp for these motors and can I use 320 geckodrive to
drive them and what power supply should I use.
I am very stuck, I need help. thank you
Old 04-13-2008, 10:31 PM
Al_The_Man's Avatar
Look on the CMC site http://www.cmccontrols.com/ if you cannot find them, I have the spec sheet for them somewhere.
[IMG] code is Off
West Amp Servomotor help johnd Servo Motors and Drives 9 12-11-2008 03:20 PM
Servomotor Alex S.A Servo Motors and Drives 10 06-10-2008 06:50 AM
Bosh servomotor quant Servo Motors and Drives 0 06-07-2007 05:30 AM
Fanuc servomotor question stude8 Fanuc 2 12-21-2006 08:55 PM
servomotor problem Alex S.A Servo Motors and Drives 16 12-24-2004 01:08 PM
