Old 03-14-2008, 10:10 PM
cnc2 is on a distinguished road
Want to mill iron or steel What do i need ?
Hi every body on the forum,
I'm about to build a 3 or 4 axis milling machine & i want it to mill steel or iron, so i'm in the "gathering info" phase because i can't figure out what it really takes to mill iron or steel, my questions are:
1) what cutting power do i need on the tool ?
2) what servo motor torque do i need for that cutting power ?
(some math please)
3)==> if you can point me on the cheapest model & a supplier for such servos, is the UHU servo controller enough to drive them ?
4) what is the best drive to suite that purpous, belt drive or threaded rod ? (some math please) (some pics of a diy metal milling machine if available)
5) No, i won't ask you to build it for me ! lol
Thanks for your readin' !
cnc2
Old 03-14-2008, 11:48 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
http://www.metalworking.com/shareware.html
download the "machine zip"
this will give a general idea of horse power and torque on the cuts you plan to do
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org
Old 03-14-2008, 11:58 PM
Thanks a lot man for the fast reply !
wow a i didn't even think this kind of soft could exsit, thank you so much !
this forum kicks a lot of A**
Old 03-17-2008, 09:07 PM
Thumbs up
man, it's a good soft, but how should the machine be constructed (designed) to resist to deformation when milling steel or iron ?
Any pic of a home built machine that's capable of milling iron or steel ?
what material is it built from ?
I have 12 mm diam rails for Y axis and 15 mm for X, these rails were salvaged from old copier machines and are 50 cm and 60 cm long respectively, will they do the job or not ?
Thanks !
Best regards,
cnc2
Tags
iron, servo, steel, torque, uhu
[IMG] code is Off
New vs old cast iron, new vs old steel ? vroemm Mechanical Calculations/Engineering Design 18 11-08-2008 01:09 AM
TIG welding Steel/Iron welding with Argon? Rich05 Welding, Brazing, Soldering, Sealing 9 12-01-2007 07:11 PM
Homemade 18x6x1.25 Cast Iron Mill Tables widgitmaster Benchtop Machines 59 05-01-2006 06:33 PM
CNC Mill and CNC Lathe offered. Aluminum and Gray Iron Castings maquiza Employment Opportunity 0 12-31-2005 10:37 AM
Iron tables for mill Swede General Metal Working Machines 6 04-01-2005 06:51 AM
