Results 1 to 3 of 3
Thread: How to control a DC Brushless motor
    Sep 2005
    Mexico
    Hello, I have a 17.5V Lincoln laser Co. DC Brushless motor, 4 poles, with differential halls and BEI encoder. This motor rotates 8 small mirrors to make a line with a laser.( I want to make it work for David laser scanner tests)
    Can someone tell me if I can use only the encoder for feedback or how to make it just spin.
    Regards,
    Jorge
    Sep 2005
    Mexico
    This is the scanner motor picture
    this is the picture
    Attached Thumbnails Attached Thumbnails How to control a DC Brushless motor-lincolnlaser.jpg
    Dec 2003
    Not sure what you are looking to do, but if you just want to rotate the motor, you could use a A-M-C drive as a variable speed drive using a pot.
    You will however need the commutation feedback, but do not need an encoder.
    BTW if you were to hook up an identical motor, the 3 stator lead to each other, turning one shaft will rotate the other in the same degree (providing no great load is on the motor). servo action.
  1. Brushless spindle motor
    By Yint in forum General Electronics Discussion
    Last Post: 03-20-2007, 12:36 PM
  2. vexta brushless dc motor
    By afifi_ytbest01 in forum RC Robotics and Autonomous Robots
    Last Post: 12-03-2006, 11:08 AM
  3. Position control of brushless AC servo motors
    By mackeym in forum Servo Motors and Drives
    Last Post: 09-10-2006, 05:55 PM
  4. a brushless motor...
    By andy55 in forum CNCzone Club House
    Last Post: 08-16-2006, 04:54 PM
  5. Help With DC Brushless Motor (Newbie)
    By genericuser in forum Servo Motors and Drives
    Last Post: 06-01-2005, 10:07 AM
