Old 02-17-2008, 01:00 PM
toneV8 is on a distinguished road
MATTKE AG servo motor
I find this servo motor.
What kaidn servo is this.
I cant rotate spindle, maybe is stuck or what?
What kaind controller to use for this servo maybe UHU controller.
How much worth this motor.
On pic can someone tell me what it is (1) and (2).
MATTKE AG
Code: LC440TRG0004A
No: 4838 05/88
260V
3350 tr/min
6,9A
4Nm
Classe: F ip65
Made in France
ID:	53611   Click image for larger version
ID:	53612   Click image for larger version
ID:	53613   Click image for larger version
Old 02-19-2008, 12:52 PM
This si specification for this servo motor on pic.
Mattke recommend to use MDR 2310 amplifier.
http://www.mattke.de/Eingang/Auswahl...5+2310_eng.htm
What kaind are brushless motors.
Name:	Servo motor Mattke.JPG‎
Old 02-19-2008, 01:09 PM
Al_The_Man's Avatar
These are resolver commutated servo's, AC sinusoidal.
They are fitted with a DC brake, the reason you cannot turn them.
1 is a resolver and 2 looks like an encoder.
Old 02-23-2008, 12:03 AM
So servo motor is AC, what kaind amplifier to use with this motor.
Old 02-23-2008, 12:15 AM
Al_The_Man's Avatar
You require a AC servo sinusoidal amplifier that will take a Resolver commutation.
In N.America you can get A-M-C drives that would probably work.
Old 07-25-2008, 03:23 AM
How to know how much watts have this servo motor, and can it be used for machine spindle.
Old 07-25-2008, 03:16 PM
Al_The_Man's Avatar
In the pic 1 is probably a resolver and 2 is an encoder.
It should perform ok as a spindle on a small mill, it looks like it will develop at least 2hp.
Old 09-11-2008, 01:15 PM
Some servo pictures.
ID:	66183   Click image for larger version
ID:	66184   Click image for larger version
ID:	66185   Click image for larger version
ID:	66187   Click image for larger version
ID:	66188   Click image for larger version
ID:	66189   Click image for larger version
ID:	66191   Click image for larger version
ID:	66192   Click image for larger version
ID:	66193   Click image for larger version
Old 09-11-2008, 01:22 PM
ID:	66195   Click image for larger version
ID:	66196   Click image for larger version
ID:	66197   Click image for larger version
ID:	66199   Click image for larger version
ID:	66200   Click image for larger version
ID:	66201   Click image for larger version
Old 09-11-2008, 04:12 PM
Al_The_Man's Avatar
That looks like the encoder you have apart, which appears to be 500p/rev differential output, which you can reuse..
The Brake (Frein) is 24vdc.
I have some motors very similar, made in France by Parvex around the same vintage.
I reverse engineered the feedback, it is a unique method that I think is no longer used, these are 20yr old motors.
Mine had three hall effect sensors which I reused and output directly to some Copley Control drive and used them as BLDC motors, IIRC, mine were 6 pole motors.
  #11   Ban this user!
Old 09-12-2008, 12:30 AM
I would like to found servo amplifier for this motor.
  #12   Ban this user!
Old 04-22-2012, 10:55 AM
Can someone help me to find servo drive for this motor.
It can be used.
[IMG] code is Off
Servo motor used as spindle motor? fatal-exception General Metal Working Machines 6 09-14-2007 02:55 AM
DC servo motor grebator Servo Motors and Drives 1 05-07-2007 08:37 AM
Servo Motor Ed Williams Servo Motors and Drives 2 04-24-2006 10:43 PM
servo motor Ed Williams Servo Motors and Drives 2 04-18-2006 01:42 AM
Servo Motor ID marvinstov Servo Motors and Drives 6 06-16-2004 10:43 PM
