| Servo Motors and Drives Discuss servo motors, drivers and other related topics here. |
| Hi all, I wonder is it possible to control a servo drive(panasonic) with pulses(from an external encoder by rotating the shaft)? I also would like to know; 1) Which type of signals do servo drives get from the host controller? 2) Do CNC's control servo drives with frequency or amplitude part of the analog signal? |
| One of the most common is ±10v analogue, torque mode drive, i.e. Transconductance amplifier, output current (torque) is proportional to voltage input. If the drive accepts step/dir, it could be possible to drive with encoder pulses, it may require some extra logic. Al.
| I am 99% sure that a Panasonic servo drive will accept step and direction, You'll need to get the manual, and or software (with RS232 cable) for the drive to set it up. Please note that the encoder will give you two frequencies, 90 deg out of phase, and the default step and direction mode on the panasonic will likely be frequency and direction and not the two pules that the encoder will do. |
| At the point of the A step pulse, the B will either be high or low, direction dependent. Al.
| servo drives help | bbrreid | Machine Problems, Solutions , Wireless DNC, serial port | 0 | 11-09-2007 02:55 PM |
| SV500 servo drives | eman5oh | Servo Motors and Drives | 5 | 02-14-2005 03:15 PM |
| Servo drives | quickerz | Servo Motors and Drives | 1 | 01-21-2005 10:24 AM |
| New servo drives? | CNCadmin | Servo Motors and Drives | 1 | 12-25-2004 08:47 AM |
| Servo motors, Drives | Wolfe | General Electronics Discussion | 1 | 11-16-2003 01:47 PM |
