Old 01-25-2008, 10:29 PM
confusion is on a distinguished road
when we say DC servomotor,
does it means motor with closed loop control, 0-180deg rotation, 3wire (V+ , GND & control), control by sending PWM? (i know this is RC type servo)
do all DC servo have the same characteristic? i mean closed loop, 0-180....
Old 01-25-2008, 11:03 PM
Al_The_Man's Avatar
Servo control is not limited to 180deg, can be any multitude of rotations through 360.
Servo is positioning by means of a feedback device.
Old 01-25-2008, 11:55 PM
routerman is on a distinguished road
Your confusing Radio Control 'servo' actuators which move an arm depending on a pulse width signal, to a motion control servo motor which is a closed loop motor and encoder.
Not the same thing at all.
Old 01-26-2008, 12:00 AM
i see! i get what you mean now...
if i rephrase it
SERVOMOTOR = MOTOR + CLOSE LOOP + ENCODER
is it correct? and the MOTOR can be brushed, brushless.....
Old 01-26-2008, 01:36 AM
so, how does a motion control servo motor control its shaft position? (like a rc servo is by PWM)
does it has a typical or common method? or it depends on the design for different types of servo which have different position control mechanism?
Old 01-26-2008, 09:44 AM
Al_The_Man's Avatar
if i rephrase it
A motion device does not even have to be electric motor, hydraulic actuators with encoder/scale feedback and hyd servo valve is also used.
The drive amplifier and its associated technology i.e. PWM, SCR, Step/dir is invisible to the motion controller.
The control puts out a command to the drive and receives position feedback from an encoder for e.g.
Technically a mechanism can be classified as servo without feedback device, as long as it can faithfully follow the command.
This is open loop servo.
The encoder provides closed loop system.
[IMG] code is Off
How many different types of encoders are there? MrWild Servo Motors and Drives 3 12-30-2007 08:48 PM
File Types Smitty911 Dolphin CADCAM 4 10-05-2007 09:56 AM
Types of aluminum spalm General Metalwork Discussion 8 11-08-2005 11:27 PM
cable types trubleshtr Computers and Networking 1 02-28-2005 08:30 PM
Your thoughts on mill types: marx911 General Metal Working Machines 4 01-03-2005 10:51 PM
