Page 1 of 2 12 LastLast
Results 1 to 12 of 13
Thread: Avoid Teknic drives, they are cheap for a reason....
    ckm
    ckm is offline
    Too many projects
    Jun 2006
    Just as an FYI to every one CNCzone. I would avoid these drives like the plague. They are often quite cheap to buy on ebay, and there is a reason for this.
    They are unwilling to answer even basic questions about their hardware and, if you ask, will tell you that they never support end-users. I asked them a simple question, and got a rather annoying form answer about 'not supporting end-users'. It may be a nice product (who knows since you basically can't use it), but the company's policies make it essentially impossible for anyone to realistically use these.
    And if you are an OEM, you can expect to have to provide direct end-user support forever and you should be aware that there will essentially be no residual value in these components (aka, Teknic's refusal to answer any questions unless you are OEM destroys the secondary market value of these devices). And, if you go out of business (not a pleasant thought, but it happens), your customers are screwed.
    I would strongly suggest anyone looking at Teknic hardware to look at Rutex or Yaskawa instead. With Rutex, you get direct access to the designers of the hardware and Yaskawa has pretty good support. Given that Yaskawa drives and motors are plentiful on eBay, they are an obvious choice for higher end servo control, even if it's trying to match drivers and motors (patience is a virtue here...).
    If you are looking at using brushless servo's with drives that are motor agnostic, Granite Devices (based in Finland) would be a lower-cost alternative. For low cost brushed servo, the Gecko drives are one of the best solutions. New, they are the same price as Yaskawa used. They have fewer features, but Mariss (the designer) is more than willing to answer any and all questions, reason alone to use his hardware. And his reasoning for providing this level of support is refreshing:
    selling electronics to cnc users
    In my day job (I do CNC and other stuff as a small side business), I advise very large companies on technology and business strategies, and the successful ones essentially understand what Mariss talks about. However, quite a few companies could learn a lot by reading Mariss's post, including Teknic.
    Yes, it's annoying to have to deal with random questions about hardware from people you've never heard of before, esp. if you are a small business, but it's far worse to just dismiss people because you can't be bothered. Esp. if you are a small business....
    As a last note, Mitsubishi Automation has some stellar support. I emailed them about specs for a 20 year old servo and they sent them to me a couple of hours later. Others have called them to get support on 15 year old controls and gotten extensive help, even though they were third or fourth owners of the machinery...
    Chris.
    Dec 2003
    Quote Originally Posted by ckm View Post
    As a last note, Mitsubishi Automation has some stellar support. I emailed them about specs for a 20 year old servo and they sent them to me a couple of hours later. .
    I will second that regarding Mitsubishi support etc., especially the Canadian MEAU have excellent technical/parts support.
    I also recommend AMC drives as a replacement for older DC drives and if you use a BLDC drive for a brushed motor , you can upgrade to a BLDC motor later.
    Apr 2006
    Chris.
    Hi Chris,
    I think you may be confusing TEKNIC with CNC TEKNIX.
    These are two totally separate companies.
    TEKNIC is based in the USA http://www.teknic.com/products/servo_drive.php
    CNC TEKNIX is based in Australia http://cncteknix.com
    We at CNC Teknix pride ourselves in our quality products & customer support.
    Thank you,
    Vince, CNC Teknix
    ckm
    ckm is offline
    Too many projects
    Jun 2006
    Vince is right. I have no experience with CNC Teknix in Australia, I was specifically referring to Teknic, an American company based in New York who make the SSt-1000 and SSt-1500 series of servo drives, among other things.
    Thanks for the clarification and sorry for the confusion.
    Chris.
    List of parts sources for CNC builders - http://www.CNCsources.net
    Dyna Mechtronics 4400C Conversion - CNC bed mill w/toolchanger to Mach3 conversion - http://www.cnczone.com/forums/showthread.php?t=50787
    Mar 2003
    I found the Tecknic drives hard to use as well. They need hard to get connectors and tech support give you the run around. Too many wires to run to each motor.
    I agree with everything you said except recommending Gecko servo drives. Their stepper drives are good, but that servo drive is just a toy.
    IMO,the Rutex or Viper drives are much better for DC servo.
    ckm
    ckm is offline
    Too many projects
    Jun 2006
    I don't think I would qualify the Geckos as toys, but there are certainly not in the same league as Yaskawa.
    Then again, then are not meant to be, they are supposed to be low-budget alternatives to systems that used to cost min. $1000 per axis.... Even Rutex drives get up there when you price out all the options.
    Chris.
    May 2005
    I will second that, that Teknic is extremely stubborn and just flat out refuses to provide any technical assistance. They do however provide excellent documentation (user manuals on their website) and if you can get their drives that are new or you know are 100% working, they really are good drives, but the service definately taints their reputation.
    May 2008
    Teknic support
    I am an OEM user of Teknic products, so I do get a better level of support than an end user would (sorry!). I too get calls from folks buying my stages and robots on ebay and want support. If I can't solve it with a quick email of wiring or a part number, it's very tough to provide more and survive, and commissioning a servo system from ground zero can be many phone calls deep.
    The Teknic guys are great, but like me, limited by how much time their engineers have for such support. I see Victors prowling around here. He's an app engineer for them, and I'll check to see if his plan is to be regularly supportive here. I think it's important, but alas, they may not. You never know what'll come of it, is my opinion.
    I'd also be happy to answer questions on their drives if folks need it. I don't agree that the connectors are hard to find, however, Molex Mini-fits are dime a dozen.
    Sorry, I don't have a defense for either of our companies not being able to support a hundred one-time users, vs. a few OEM's ordering thousands of the same thing. Wish I could! I'll talk to them about it and see if there are some documents that could be made available that'll take the sting out of no-one at the other end of the phone. Don't throw out those amps yet! They're the highest performance for the buck you're going to see, but yeah, not exactly plug and play! ;-)
    Mike Visit my projects blog at: http://mikeeverman.com/
    http://www.bell-evermannews.com/ http://www.bell-everman.com
    ckm
    ckm is offline
    Too many projects
    Jun 2006
    I didn't ask for support, just documentation. The answer was NO.
    In my view, that makes them the worst of the worst companies to deal with. Basically, proprietary to the n-th degree and worth staying away from even if you are an OEM. If you go out of business, your customers are screwed and that's never good.
    Note that there is a similarly named company in Australia, but they are not related and do provide good docs and end-user support.
    Chris.
    May 2008
    Point is, if you still want a doc, I can get it for you. I do get it, though. It is a very sophisticated amp and would be difficult to "hunt and peck" through the settings.
    Ever used a Delta Tau control? sheesh If you really need to do anything bleeding edge, it's the thing, but try to get support, even as an OEM! Same deal, and any of the 10,000 variables set wrong can de-rail you. There are hundreds of control solutions out there that will go unsupported for ebay buyers.
    Again, though, it pains me to hear someone needing something simple and not getting it, in order to use this fine product. For no one in particular but myself, I'll see if I can A: get more docs available online, or B: see if anyone there wants to keep an eye on a forum here. It's an amazing amp and worth some effort.
    Just so you know, Bearing Engineers in California private labels these amps (literally just a different color), and maybe they have more on their site, or with a call. Though we'll all have trouble getting phone support from distributors when we did not purchase from them.
    Sep 2009
    Mexico
    Teknic is not bad
    Hi Guys
    I personally liked this thread much, because I am somewhat in between of you two.
    I am a DIYer that purchased several Teknic drives (SST-1500), and some motors and started doing tests and automating stuff... You know. The works.
    I too had a limited response from the support team, and more even a worse one from the sales team, stating that I needed to buy large qty's for them to sell to me.
    All that is true. What I can say for all you who are considering buying these drives on ebay is this: GO FOR IT!!! They have SUPERB documentation available on their website, all you have to do is "register", (which means entering your info, that's it. No commitment, no nothing), and the drives are fantastic, they work flawlessly, and are REALLY simple to work with one you READ THE MANUAL.
    It's as simple as that... I have implemented them in 3 - 5 diferent projects now.
    On the other hand, since those DIY days, I now work on a company which are requiring these types of systems, and am in process of instating these drives as a std for our solutions, and hoping to become an OEM large enough for them to service me directly.
    By the way Mike, I saw your site, (BellHome), you guys have some awesome solutions.
    I'll give u a call next week to discuss them.
    Thanx!
    Hope this is helpfull
    May 2008
    Great amps
    Thanks for the kind words. I look forward to your call. Here's a test I did a couple of weeks ago using those amps on a KAOS Robot. Very fun piece of work!
    "http://www.youtube.com/watch?v=i5jGBE-Xcg4"]YouTube - KAOS Robot doing a high speed pick and place move
  • Page 1 of 2 12 LastLast
    1. Anyone Using Teknic SST-1500 Servo Control?
      By CJL5585 in forum Servo Motors and Drives
      Last Post: 04-21-2012, 10:45 PM
    2. Interact Bosch servo drives for cheap!!!!!!
      By Interact77 in forum Bridgeport and Hardinge Mills
      Last Post: 02-01-2010, 06:29 PM
    3. any one have or seen Teknic SST-1500 servo amplifier
      By chrisw765 in forum Servo Motors and Drives
      Last Post: 09-16-2009, 10:23 PM
    4. Teknic SST-3000 Drives
      By jeoffrey in forum Servo Motors and Drives
      Last Post: 09-16-2009, 10:22 PM
    5. Teknic SST-6000 Problem
      By Cold Fusion in forum Servo Motors and Drives
      Last Post: 07-29-2005, 05:39 PM
