Results 1 to 5 of 5
Thread: servo motor
    Apr 2006
    na
    servo motor
    can someone correct me but do servo motors have constant torque for wide range of rpm. If so why dont we see more people using them?
    Mar 2003
    Shelby Twp, MI....USA
    Fairly constant, yes. The reason that steppers are used more is because they are much cheaper. A 3 axis servo system will usually be about $800 and up, while you can get a HobbyCNC board and steppers for about $300.
    Apr 2006
    na
    servo tunning?
    whats involded in tunning servo for x, y? need someone to
    explain whats different than stepper set up..
    Jun 2003
    Boalsburg PA
    you will rarely see a stepper system that can overshoot. A servo system can be underdamped, and oscillations are possible. You generally want to be critically damped if at all possible. Need more info to give a better response than that.
    May 2007
    France
    the controller compares the wished position end the actual (real) position, and function of this applies more or lesse current (ie. torque) in the servo.
    You'll usually have 3 parameters to tweak: P, I and D
    google PID and you'll find more bout it.
    usually servo are better because you don't suffer of the steps missing, have a more silent motor, no vibration (if well tuned), more speed etc. etc.
    steppers are cheaper thought.
    and don't be fooled by the microstep, they don't really makes your steppers more precise, just less vibrating.
    1. AC servo motor vs DC servo motor
      By BarneyW in forum Servo Motors and Drives
      Last Post: 01-30-2013, 10:21 AM
    2. Servo motor used as spindle motor?
      By fatal-exception in forum General Metal Working Machines
      Last Post: 09-14-2007, 03:55 AM
    3. Servo Motor
      By Ed Williams in forum Linear and Rotary Motion
      Last Post: 06-17-2006, 04:49 PM
    4. servo motor help
      By max_imum2000 in forum Servo Motors and Drives
      Last Post: 01-07-2006, 11:28 AM
    5. servo motor
      By mace in forum DIY CNC Router Table Machines
      Last Post: 02-08-2004, 04:07 PM
